Question about Hitachi 42PD6600 42 in. HD-Ready Plasma Television
Cant tune tv in - Hitachi 42PD6600 42 in. HD-Ready Plasma Television
Please can anyone help i cant tune my tv it wont pick up any channels when i auto tune it it says weak or no signal but i plugged aerial and tuned another tv and its fine
Are you trying to get over the air channels? IF you are does your TV have the digital tuner on analog? TV went digital and if you have an analog tuner will need either e new TV or converter box.
Jul 01, 2015 | Samsung 65" F9000 Series 4K Ultra HD Smart...
Cant tune channels
It sounds like you need to do a complete installation as if TV were new.
This is done from installation menu
Feb 14, 2014 | RCA Televison & Video
How to tune tv without remote
If there is a Menu button on the front panel of the TV you can surf thorugh its menu, and select auto tune function. If there is no such button, you must have its remote control to do this.
May 04, 2012 | Televison & Video
Cant remember how to tune it in
  1. Turn on your TV.
  2. On your Tune In remote, press TV and release.
  3. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  4. Enter the first three-digit TV code for your Sanyo from the list which follows:
    154, 159
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  5. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
  1. Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
  2. If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
Jul 30, 2009 | Televison & Video
Cant pick up any stations
Does this TV have Digital?
You might need a converter
Jul 25, 2009 | Televison & Video
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tuning TV onto AV chanel
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Apr 01, 2008 | Televison & Video
Tuning
Same here. I have the tv with a hitachi r/c CLE-87613 but can't tune the tv to the aerial channels.
My email is tonyhutchinson@hartsheadgroup.co.uk
Nov 27, 2007 | Televison & Video
Cant tune my Hitachi TV
please check web site for any thing in remote. www.remotes.com and give model name in search. hopr this will help. good luck.
Sep 30, 2007 | Televison & Video
Hitachi 42PD6600 42 in. HD-Ready Plasma Television Logo
13 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
