Question about RCA ViSYS 2-Line Speakerphone
RCA visys handset says registration complete but is not registere
Instruction manual for RCA visys 6.0
Good morning,
How do I retrieve voicemail messages on this system?
Sep 08, 2014 | RCA ViSYS 25255RE2 2-Line DECT 6.0 Digital...
On the screen of the phone says not registered and wont allow me to make phone calls or recieve
Please try the following procedure to register the handset:
  1. Place the unregistered handset in the telephone base. If PRESS FIND HS 4 SEC ON BASE does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows PLEASE WAIT... and it takes up to 60 seconds to complete the registration. The handset shows HANDSET X REGISTERED (X represents the handset number assigned) and you hear a beep when the registration completes.
When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset will be HANDSET 3
Mar 05, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Phone displays a message saying no link to base when it is closer to the base?
Following may be the cause for getting no link to the base.
1. The handset has lost communication with the base unit.Move closer to the base unit, and try again.
2. Confirm that the base unit’s AC adaptor is plugged in.
3. Raise the base unit antenna.
4The handset’s registration may have been cancelled .Re-register the handset.
To Register, follow the below steps.
Headset: Press MENU and then press ‘0’ ‘0’
Base unit: Press and hold HANDSET LOCATOR until the CHARGE indicator flashes.
(After the CHARGE indicator starts flashing, the rest of the procedure
must be completed within 1 minute.)
Handset: Press OK, and then wait until the handset beeps.
Your handset is registered to Base unit.
Thank You
Aug 18, 2010 | Panasonic KX-TG2620 Cordless Phone
I want viking mp3 player 3.62 registration code
i want mp3 player 3.62 registration code
Jul 28, 2010 | Nokia Lands Phones
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
Need to set time & date on the cordless. RCA Model No. H5401RE1-A
From page 14 of the manual: "The time cannot be set manually in the handset, only at the base. Any update to the base time will be automatically sent to the handset."
Apr 08, 2010 | RCA ViSYS 2-Line Speakerphone
RCA ViSYS 2-Line Speakerphone Logo
21 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
