Question about Pioneer PDP-5010FD 50 in. Plasma HDTV
Pioneer pdp5010 fd flashing 8 times then flashes 12 times blue
  • 41 Answers
SOURCE: Powers off by itself
You need a firmware upgrade that has to be done by a tech onsite. I've done many of them. 12 Blue blinks is a TVGuide download trouble and doesn't hurt the set but a firmware update should solve it. If it occurs again after that you need the Main Assy replaced but make sure the firmware is updated on that also.
Problem will go away
Hope this helps
Posted on Mar 30, 2009
  • 8457 Answers
SOURCE: after off for a while,
Ur tv have a dying power supply board,that the board where the power a/c cord plug into.U have all the tools and know basic electronic also can do basic soldering work?Yes,take the tv aparts and check the tv power supply board carefully looking for dying capacitors components parts.These dying many capacitors components parts are alway bulges up or puffing up onto it tops.These capacitors parts are slowing leaking and dying to causes the tv to have a unstable managements of power voltages to tv to powering up the tv,unstable power supply board source that why the tv LED power light indicator are flashing.Replaced all these dying and leakages capacitors components parts are bulging ups or puffing ups onto it tops.Replaced all these dying capacitors parts with the same Micro Fared and but it voltages higer like 5 or 10 voltages higher than the old capacitors parts u are replacing.These higher 5 or 10 voltages on the new capacitors parts will help it to with stand heat better than those old capacitors parts u are replacing.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.
Posted on Aug 15, 2011
snakehead
  • 1074 Answers
SOURCE: unit will shut down and
its a B+ OVER CURRENT PROTECTION it could be you have a short in the in the power supply of any circuit pertaining to the power supply check T602 AND R672.good luck.
Posted on Sep 13, 2011
gopakumarg43
  • 74383 Answers
SOURCE: Problem with Pioneer PDP-6010FD
Hello
The set can be set right by repair. You must have through knoledge in electronics to do work with set. especially, plasma displays will have very complicated circuits. It Sustain-Boards suld be trouble shooted.
Posted on Feb 22, 2012
spr1949
  • 1182 Answers
SOURCE: blue light flashes 8 times no pic
This is an error indication of defects inside the TV and might need service.
Posted on Aug 29, 2012
Pioneer 5020 will not power up and blue light flashes 8 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Feb 15, 2014 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Blue light flashes 8 times no pic
Aug 28, 2012 | Pioneer PDP-4280HD 42 in. Plasma...
Hello
Feb 21, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
Unit will shut down and go into standby mode blue standby light will flash 12 times
Sep 13, 2011 | Pioneer PDP-5010FD 50 in. Plasma HDTV
I have a pioneer gm-d8400m the amp isnt working
flashing light could mean a few different things. 1- constant power may not be there. check with a test light or multimeter. should read around 12 volts. it would be a good idea to check all the power and ground leads. make sure u have a good ground. 2- bad sub. im assuming sub since its a monoblock amp. you can meter the subs. make sure the total ohm load is no less than 2 ohms. any lower the amp will go into protect mode. 3- bad amp. power supply may be bad. the newer pioneer amps are full of protection circuits. ive been a professional installer for a shop about 8 years and we sell pioneer. hope it helps.
Dec 25, 2009 | Car Audio & Video
Media Receiver Shut-down, Blue LED Flashing for Pioneer PDP-R06G
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
May 10, 2009 | Pioneer PureVision PDP-4340HD 43 in....
Hope this helps
Mar 14, 2009 | Pioneer PDP-4270HD 42 in. Plasma...
I have an Elite faltscreen television that has been working well for over one year. For an unknown reason, the blue light (next to the on/off switch0 is blinking and the TV is not responding or turing...
Please count the number of flashes of the Blue LED. It will flash Ex. 12 times and pause for 2 seconds and then flash 12 times again. The number of times it flashes will tell me more as to what the solution is. I am assuming the set works otherwise ?? What is the model number of the set ?
Scott
Feb 14, 2009 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Pioneer PDP-5010FD 50 in. Plasma HDTV Logo
21 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
