Question about Tascam 2488 Portastudio Multitrack Recorder System
My tascam portastudio DP-03 freezes on the loading screen then wont turn off unless i pull the plug
The lights flash and then it stops and wont do anything
ginko
  • 19396 Answers
SOURCE: tascam 2488 digital portastudio
Your HD risk to be corrupted, probably need to be removed and tested on a different device, I see if I can find the schematics
regards
Posted on Mar 08, 2008
  • 189 Answers
SOURCE: Tascam Portastudio 424 Manual needed
Try this page: http://www.tascam.com/products/424mkiii;9,17,141,19.html
Regards,
BD
Posted on Apr 25, 2008
  • 189 Answers
SOURCE: load imported songs on tascam dp02 cf
Make sure you have the song loaded first. In this case it sounds like you are importing into a new song, so make sure that you have a new song created and loaded prior to importing.
Then go to the menu by pressing the 'MENU' sutton and from there select 'WAVE' and then 'IMPORT TRACK'. You'll see the list of wav files on the fat partition of the CF media displayed. Select the wav file with your beat track on it (use the DATA DIAL or up/down arrow buttons to highlight the right wav file) and press the 'YES/ENTER' button. You'll be prompted for the track to import into. Select Track01 and press the 'Yes/Enter' button again and the WAV file will be read and inported into track 1.
Please note that the wav file should be a 44.1 kHz, 16-bit and a mono wav before trying to import it. If the beat track was created as a stereo wav you'll have to go into a wav editor like Audacity and resave the file as a mono wav file first. Also for a wav with a bit rate higher than 16-bit, the DP-02 is going to truncate the bits rather than dither and this might effect quality adversly so you might want to make sure that the file is properly saved as 16-bit prior to attempting an import to avoid this.
Hope this helps.
bd.
Posted on Jan 12, 2009
SOURCE: Play and Record button not working
I have the same problem with all three of my Tascam 2488 MKII's.
It's a software problem and starts to show up when the harddisk gets full.
Backup your song files ( something you have to do anyway ) and then reformat the entire hard disk.
Then restore the songs you were working on lately.
Before doing this rather huge task, you can copy your latest song to another partition and go on with this copy.
This is only a provisional solution.
Hope this helps !
Best regards
Posted on Feb 25, 2009
SOURCE: Tascam dp-02cf Problem Play Button Flashing
I just had the same problem with my Tascam recorder. Did you ever find a solution? I really don't want to lose all the work I've done
Posted on Jun 23, 2010
How do I set my Tascam DP-32 to record 24 bit 48kHz?
Dustin, just go to song in the menu , click the arrow to song load, create etc. cursor to song create and it will give you the option of 16 or 24 bits just turn the cursor wheel then just cursor down with the button and select 44.1 or 48 kHz . Then cursor up to song load and push the right arrow and it will load your song with the settings you have selected. Very good recorder once you learn your way around on it. Joe
Nov 12, 2014 | Tascam DP-32 32-Track Digital Portastudio
How do I import a CD created on the Tascam DP-02 into the Tascam DP-32?
I have the Tascam DP-02 it uses a fat 32 partition, Fat 32 partitions are pretty much obsolete replaced with the New Technology Filing System or N T F S for short. Using the DP-32 systems software try plugging the DP 32 in to your computer once the software for you new unit loads locate and open the fat 32 system folder I'm not sure if the DP 32 uses the same fat 32 partition, But if it does the fat 32 folder should be there, Locate and open it you should then be able to move or delete your recorded material as desired
Oct 04, 2014 | Tascam DP-32 Portastudio 32trk Digital...
My tascam dp-03 track 4 rec button is unresponsive and doesnt light up but it was just working yesterday. the volume slider still works.
Some time with dust or Humidity there is a contact issue with the switch and the circuit so you need to get some contact spray spray it and should start working well.
Apr 18, 2014 | Tascam DP-03 DP03 8-Track Digital...
Tascam DP-01FX/CD wont turn on
Refer to your manual (1st) It appears that "maybe" your unit may be
locked - until you get through the menus - and type/press EXIT.
If you don't have a red indicator light - lit. Turn off power switch (rear)
and unplug unit for 1 minute. Plug in - then turn on switch (rear)....if
still no red indicator light....you'll need either Tascam or Samsung
tech to service your unit. Good Luck.
Feb 28, 2014 | Tascam Digital Portastudio Dp-01fx/cd
Why does the screen read "device error" when I turn it on?
http://is.gd/B05L6B
According to the user manual for the device, on page 81, it reads:
If any of these errors occur, turn the the unit power OFF and restart it.
If these error message continue to appear, please contact a TASCAM Service Center.
***Device Error*** (the one you're asking about)
FileErr
FX Busy
FX Rx Failed
I
/F Error
Mount Error
SaveParam Fail
SD-Card Error!
SD Not Found
SD Read Busy
SD Write Busy
Looks like your unit may require servicing at an authorized Tascam service center.
Good Luck!!
Oct 12, 2013 | Tascam DP-03 DP03 8-Track Digital...
Manual required for tascam portastudio 03
If you have the model DP-03 then the manual download can be found at:
http://tascam.com/product/dp-03/downloads/
If that is not your model, the other models manuals can be found at:
http://tascam.com/support/downloads/
Jun 02, 2011 | Tascam Audio Players & Recorders
Aug 27, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
62 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
