Question about Sentry Audio Players & Recorders
Sentry hm455 mic does not work on computer - Sentry Audio Players & Recorders
Sentry headphones with mic
My mic DOES pick up stuff, we just can't quite figure out where the mic actually is so we can talk into it and actually hear us talking pretty well, we can slightly hear us talking into it in a recording, but it's so low! (we/us being me and my friend)
Jan 28, 2012 | Sentry HO900 Headphones
I got a sentry industries headset but the mic isn't working on skype it say on the box that it works with skype but when i connected the mic it wasn't working in skype . please help me how can i...
try to to see if it is plug on the right mic socket, usually pink. and make sure that you record directly on your mic,
go to control pannel choose sound and audio devices (on vista and window 7 just search for sound and devices or the volume control on the startmenu), and click on the advance button.
choose option properties and choose recording
make sure that you check the mic and increase the volume as musch as possible
try to adjuct the mic setting on the skype by calling the sound test service
May 09, 2011 | Office Equipment & Supplies
I'm trying to use my PG mic and connect it to my computer to record but I can't hear myself in the computer. The mic works if I connect it to a monitor. My audio is fine and my computer mics work fine on...
To connect a professional mic to a computer, you will need a USB interface such as the Shure X2u. Professional mics have too low of an output level to be connected directly to a computer.
May 03, 2010 | Shure PG48 Consumer Microphone
How do I set my Sentry talking clock?
Many Sentry product manuals can be down loaded from the following URL
http://www.sentryindustries.com/support/manuals.asp
The instructions for Sentry CR104 is located at the following URL
http://www.sentryindustries.com/pdf/instructions/CR104_instructions.pdf
This may be unrelated to your problem, but
I have noticed sometimes the instructions tell you to use the ADJUST key.
If that does not work try the SET key sometimes it will work instead of the ADJUST key.
Mar 12, 2010 | Sentry CR104 Clock Radio
Sentry Key system won't let me start my Jeep Grand Cherokee
get a new key. you can easily bypass your alarm to ignition conection, worked for me!
Feb 12, 2009 | Chrysler Sentry Key Immobilizer Bypass for...
Sentry remote
what is the code for a rca 52 inch tv
Jan 17, 2009 | Sentry Remote - Parental Control Software...
No Sound Coming out my Microphone
i know this might sound a little obvious and maybe irrelevant to the problem, but did you press the switch on the mic? it will turn the mic on and off. make sure sound and mic are unmuted in windows volume control. if both are these didnt solve the problem, test the mic on another computer. if the mic works, maybe its not the mic that has the problem. if the mic doesnt work, then your mic may be defective or damaged in some way or other.
Mar 28, 2008 | Philips PH62080 Uni-Directional Microphone...
Microphone isn't working with the computer.
1-select start2-select contrrol panel3-select sound speech and audio devices4-select sound and audio devices.5-confirm that mute box not signed.6-pres advanced in mic volume confirm mute box not signed7-select audio you will see capture screen in mic volume sign select.8-in default device press volume you will see volume control screen in mic volume confirm that mute box not signed
Mar 02, 2008 | Philips PH62080 Uni-Directional Microphone...
Acknowledging Microphone
Sounds like the mic is bad. The only way to confirm this is to plug a different mic into the computer and see if that works. If the second mic gives no sound then the computer may have an issue. Hope this helps.
Nov 04, 2006 | Logitech (980240-0403) Microphone
29 people viewed this question
Top Sentry Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Vincent Cruz
Tom Chichester
Are you a Sentry Audio Player and Recorder Expert? Answer questions, earn points and help others
