Question about Garden
I have a John Deere 265 mower.The problem I have is I had to replace the 17hp Kawasaki engine. I installed a Briggs & Stratton 14hp engine, everything works fine, but I don't know what to do about the wiring for the altenator. The Briggs has a 2 wire plug and the Kawasaki has a 2 wire plug, but with the key in the run engine off position if I hook these wires up the battery light goes out which it should not. Any ideas? Any help would be greatly appreciated.
  • Anonymous Mar 17, 2014
    john deere zero turn with a briggs and stratton motor husband replaced solenoid and did not hook back up need to know witch small terminal to put the green and purple wires on there is a plug behind pos.terminal and one behind neg terminal
  • Anonymous Mar 31, 2014
    just need to know what wire goes to the battery so it will charge. I have a Kawasaki engine
I fixed this problem myself. This alternator had a diode in one of the wires, just take it out,problem solved.
Posted on May 21, 2009
Briggs and Stratton 17 HP Riding Mower
Hi Lawrence.
There should be a few more numbers/ letters to your model number. I added a link to a website for you to check out. Click the link or copy and paste it. Hope this helps.
https://www.repairclinic.com/Shop-For-Parts/a22b303d782009/Model-42A7072653E1-Briggs-Stratton-Small-Engine-Parts
May 30, 2017 | Briggs & Stratton Garden
John Deere won't start after sitting over winter. I hear the carburetor needs to be cleaned but I don't know where it is or where to start in the removal of it from the motor mount
because John Deere has used Onan, Kawasaki,Tecumseh,Briggs and Stratton one cylinder and two cylinder gas engines you will need to Give the Tractor model or engine information to get any help on this question .With that information it will be easy to get you pictures and video of this job.
May 21, 2016 | John Deere Garden
John deere 170 with a kawasaki 14hp engine. Battery has 11 volts. I turn the key nothing happens when I jump the solinoid the starter hums. Any help is greatly appreciate
Battery is low. Either the battery is bad or the charging system is bad. You should read 12.5 volts or more when not running, 14 volts when running.
Mar 29, 2016 | John Deere Garden
How to fix ajohn deere L120
what kind of engine does this have Kohler, Briggs and Stratton , Kawasaki, etc.. need this information. There is a thing under the flywheel called a stator ( alternator ) a lot of times on Kohler the magnets inside the flywheel comes loose and sticks to the stator and then cannot charge the battery.also the regulator could be bad
Jul 28, 2014 | John Deere Garden
17hp briggs and stratton blowing oil out of dipstick
looks the rings are stuck.when you have head off check piston. john.
Mar 10, 2014 | Briggs & Stratton Garden
John Deere Walk Behind Mower
remove the tin cowling and check for rubbish build up preventing the air cooling the fins of the motor.
Jun 14, 2013 | John Deere Garden
Need carburator ajustment / john deere lx176/14hp kawasaki
i have 14hp kawasaki that backfire throw the carb and exhaust what could it be
Jun 05, 2012 | Garden
Scotts by john deere riding mower - 220 hours, 17.5 HP, 42" cut, Briggs & stratton engine -- New Strarter, new battery, good fuel... will turn over but engine will slow down then stop, will not...
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
May 15, 2011 | Briggs & Stratton Garden
What Engine Model Number is in a John Deere LT166
http://www.deere.com/en_US/govsales/purchaseguide/PDFs/124_125.pdf
Will give you all the info you could need about the LT 166.
The LT166 uses a 303777 Briggs & Stratton Engine
The LT180 uses a FH500V-AS32 Kawasaki Engine, 4 Cycle
The LT190 uses a FH580V Kawasaki Engine.
The LX289 uses a FD501V-DS04 Kawasaki V-Twin Engine.
The X354 uses a FH721V Kawasaki with 4 wheel steer.
Hope this helps.
Apr 13, 2010 | Garden
Garden Logo
378 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
