Question about Pioneer Computers & Internet
Error 2A030C00 error whilst using EZ CD from Poiksoft
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: I'm trying to burn a
im not sure what this error message is or means but you could try this
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software or only if you don't need to
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive this should schedule to happen when you restart your computer then defragment your hard drive
you should not have any imput on your computer while the chkdsk utility is in progress may damage your computer
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Posted on Jun 19, 2011
Why is there an error message: Space Not Enough when trying to copy DVD?
There is some space reserved for dvd information, error information etc. So solution is make the file archive by right click on file ->proprties-> click archive. After that use winrar and compress. http://www.rarlab.com/download.htm
Aug 22, 2013 | EZ Dupe Computers & Internet
I have the same problem with my laptop. It's Toshiba Satelite. When I want to burn cd computer says that's an error whilw I'm burning, gives me this code: 3802F6-26-2A030C00 and maybe there's a dust or...
Sounds like the beginning of hardware failure i would like take advantage of the warranty if its still available.. in the mean time try using an alternate burning software i recommend cdburner xp its free and easy to use.
here is a link:http://ninite.com/cdburnerxp/
Feb 28, 2011 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
I was trying to record documents on a cd when I got the following message: Code erreur 380394-26-2A030C00
HI ,
1° It could come from the cd . Try with other models .
2° Go to my computer and right click on dvd device and click on properties then click on recording see if your decice is checked for burning.
3° Try restoring your computer to an earlier date , when your drive used to work fine .
4° Connect an external device and see what happens . If it works , your burner needs to be replaced .
Best regards .
Jan 24, 2011 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
380381-26-2A030C00 I get this error code whenever I try to burn a cd. Trying to figure out what is the problem because the burner works perfectly on dvds. Thanks for your help
Trying other burning software is a good Idea, windows itself has native cd burning support,through media player for example. It won't be a codec issue unless you are converting from an MP3 or similar.
Try burn with deep burning
Download it from following bellow link
http://www.deepburner.com/?r=products&pr=deepburner
I personally don't like codec packs, they fill your system with codecs you never use and aren't as up to date as the individual codecs.
I always install Koepis's latest Xvid Codec and AC3 filter and that's it unless something fails to play, then I find the relevant codec.
The question regarding DMA is also worth following up, from device manager you need to check the properties of the IDE controller the drive is connected to - can take a bit of trial and error to find the right one. It should be set to "DMA if available" and the current transfer mode should be something like "DMA mode 2" ( depending on the drive ) If it is in PIO mode that will cause issues.
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 10, 2011 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
We have an EZ Dupe 9 burner that used to burn dvds in the past. We started recording our sermons on dvd and finalizing them, but they won't copy in our EX Dupe? serial number 190605054
Dianna:
There should also be an error message associated with the unit not being able to duplicate DVDs when you attempt to do them in the duplicator. Please provide that error message or whether or not it locks up. Also, given this is somewhat difficult to do over the internet, please feel free to call us @ 877-686-8868 x208 for technical support and we will be glad to assist you. Thank you for your inquiry.
Sincerely,
EZ Dupe Technical Support
Nov 10, 2010 | EZ Dupe (EZD1TDVDNEC) DVD±RW Burner
What do you when it says target disck is not ready on a duplicator
Your disk *WITH* the data is the "source" disk.
Your "blank" disk is the "target" media.
Try a different "blank" disk.
If not any better, then take the unit to a computer technician, to trouble-shoot the hardware that is used to write onto the "target" media.
Apr 02, 2010 | EZ Dupe 1-Target CD/DVD Duplicator with...
EZ Dupe CD/DVD Duplicator keeps giving the error message, 'Source Not ready" No matter how many different CDs I put in the top disc slot, it keeps detecting an error
Have you tried cleaning the lens?
3M makes a CD lens cleaner that is a playable CD with micro brushes sticking out of the surface of the CD.
You can find them at office supply stores, K-mart, etc. I don't remember where I bought mine, but it works great for a CD-recorder that I use in a high dust environment.
Here's a link to one that I just found by googling "3m cd lens cleaner"
I've never dealt with that vendor before, but it has a picture of the product so you can see what I'm talking about.
Feb 12, 2010 | Computers & Internet
Problem with my Asus p5pe-vm motherbord.When i start it,the message CPU uCode loading error appears.What to do...HELPPPPPPP
If your over clocking your CPU settings reset to default. See if you still get the error. If you still get the error than update your bios. There are a couple of way to do this. You can use the software on your Asus CD or you can down load the latest BIOS-Utilities, Afudos BIOS update tool V2.36. Than download the bios file, P5PE-VM BIOS 1501.
http://www.asus.com/product.aspx?P_ID=k3h0ZFVu9Lo1dUvk&content=download
Using built-in EZ Flash to flash BIOS Please be informed that not all motherboards support EZ Flash,
please use DOS flash utility to update BIOS if your motherboard does not support EZ Flash; http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=960&SLanguage=en-us
Happy holidays!
Mike
Dec 19, 2009 | ASUS P5PE-VM Motherboard
Ez cam installation without cd software
Hey,
The drivers are located here...http://www.shopezonics.com/Articles.asp?ID=108  Just scroll down the list to select your model. And install your webcam using the driver file you just downloaded
Thanks.
Apr 15, 2009 | Ezonics EZVideo Chat Kit Webcam
Computers & Internet Logo
110 people viewed this question
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
