Question about NetGear WNR2000 Wireless Router
Can not connect chromecast to netgear wnr2000 v3
Chromecast can not connect
  • NetGear Master
  • 2,219 Answers
You need to follow the instructions of connecting the Comcast to a PC first, and setting it up.
Then you connect it to the PC and access the router wirelessly.
Posted on Mar 08, 2015
  • stephen Adams Mar 08, 2015
    Then you connect it to the TV and access the router wirelessly.
redhaze89
  • 854 Answers
SOURCE: Myh new Netgear WNR2000 won't connect to my cable
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
Since your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jul 11, 2009
JaxPlanet
  • 922 Answers
SOURCE: cannot get online usinh netgear wnr2000 router i
Configure your computer's network adapter to use DHCP and make sure DHCP is enabled on the Netgear.
Posted on Aug 09, 2009
  • 27 Answers
SOURCE: Problems connecting with a Netgear WNR2000
your easiest solution is probably just to reset everything back to defualt settings. there is a small pin hole button on the back or bottom to do this.
hope this helps!
Posted on Aug 24, 2009
  • 117 Answers
SOURCE: how to connect my netbook to my netgear wnr2000
follow is the steps to connect vista
Perform the task below on the wireless VISTA computer:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
7. This should setup the wireless network.
You can visit the link below to follow the steps in case the issue occurs again:
http://netgear-us1.custhelp.com/app/webagent/detail/a_id/95
FOR WINDOWS XP:
1. Click Start and Goto 'Control Panel', then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Check the option " Use windows to configure my wireless network settings"
5. Under Preferred networks if you see any name in the list then highlight the name and click remove.
6. Click on ADD button. Enter your network name exactly as you have on the router. (This is case sensitive).
7. Under network authentication select Open and for Data Encryption select WEP.
8. Uncheck the box for " The key is provided to me automatically"
9. Enter the network key in the box provided. Select Key Index as 1.
10 The option " this is a computer to computer (Adhoc network;wireless acess points are not used) should be unchecked.
11. Click OK
12. Reboot the computer and check if you are able to connect to wireless network.
regards
prakash
Posted on Mar 21, 2010
  • 33 Answers
SOURCE: My new Netgear wnr2000 keeps dropping connection
well if ur Router is a NETGEAR , on the Router GUI
i mean Log into Router with 192.168.1.1
username is admin & password is password
go to Left side Blue Screen
click on WAN SETUP under Advanced
Check the Disable SPI Firewall
Select MTU Size as 1400
also set the NAT filtering as Open
Apply settings i am sure issue Resolved
All the BEST..............
Posted on Oct 24, 2010
How do I connect my router N600 to Chromecast?
  1. Check your NETGEAR router settings
  2. Uncheck Enable Wireless Isolation This step will disable AP Isolation.
  3. Uncheck Disable IGMP Proxying This step will turn Multicasting ON.
Feb 15, 2015 | NetGear WNDR3400 N600 Wireless Dual Band...
Dec 28, 2013 | NetGear WNR2000 Wireless Router
How to reset wnr2000 v3 to factory settings
Push and hold the reset button for 30 seconds or so, release.
Jan 16, 2013 | NetGear Wireless-N Router WNR2000
Can't get on my wireless
Try resetting the router and try the same .
Oct 21, 2009 | NetGear WNR2000 Wireless Router
hope this helps!
Aug 24, 2009 | NetGear WNR2000 Wireless Router
Netgear wnr2000
You should not need any software to connect to the router. Use connection wizard in VIsta to setup the internet connection
Aug 16, 2009 | NetGear RP614 Router
NetGear WNR2000 Wireless Router Logo
107 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
