Oley d9h remote codes - Office Equipment & Supplies
Tip
I need a config. my remote control UEI By DirecTV
<span>If you are using the universal remote control provided by directv, try these codes 10054, 10030, 10171 <br />OR:<br /><b>Satellite TV Systems</b> Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 <b>Cable TV Systems</b> Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote "UEI" URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610 For the LTxxxxx series: You can use the codes listed under RCA, LG, Philips or Yamaha. <br />Thanks</span>
on May 07, 2011 | Televison & Video
I have an Oley LCD projector which is showing some
try reversing a vaccum cleaner aand blow out the cubweb.... projectors lasers aare sensitive... you might damage the unit permanently...
Jul 19, 2009 | Office Equipment & Supplies
Hd flashes every few minutes
THE DEVICE THAT HELPS THE SYSTEM FROM OVERHEADING MAY HAVE BURNED OUT IT IS SOME TYPE OF TRANSISTOR THAT HAS PHOTO CELLS IN THE COMPONET TO KEEP THE SYSEM OPERATING PROPERLY.
YOU CAN GO ON LINE AND TYPE THE FOLLOW INFORMATION IN THE ADDRESS BAR
NEC VT47 MULTIMEDIA PROJECTOR LIGHT FLASHING
ENTER
THIS IS TO SEE IF ANYONE ELSE IS HAVING THE SAME PROBLEMS AS YOU AND WHAT THEY HAD TO DO TO FIX THE PROBLEMS.
ROD GANDY
Feb 10, 2009 | NEC VT47 Multimedia Projector
How to replace an hp 070 projector lamp
undo the top cover you will see a black cover with clips and at the back or side there are two small screws which hold the rear concave mirror in place undo the screws bend the clip back gently and remove ....pop out old bulb and put in new bulb with a piece of tissue dont touch it with your fingers.... do all the rest in reverse order ...did mine tonight took 10 minutes just a bit tricky getting screws back in.....you need a long magnetic posidrive with a small head....
Dec 04, 2007 | Office Equipment & Supplies
Projector giving upside down picture
for the VT465 it is in the menu under "setup" then "orientation".
Page e-24 of the manual.
http://www.douglas.bc.ca/__shared/assets/NECVT_660K_MANUAL32261.pdf
Nov 29, 2007 | NEC VT465 Multimedia Projector
77 people viewed this question
jasbo
jasbo
