Question about Dryers
My whirlpool dryer model wed9400sw1 wont heat but will do everything else
zeusfaber
  • 247 Answers
SOURCE: no heat
First port of call is thermal cutouts - little switches that monitor the temperature of the air going into the drum and cut the heat off before it sets your house on fire if something goes wrong and it all starts to get too hot.
Disconnect the power, then open the machine up. Look for the metal duct that directs the hot air into the drum (you'll recognise it by the funny-shaped blower bit at one end, and the collection of terminals sticking out of it at odd places about halfway along).
You'll find that some of those terminals are associated with flat coin or button like objects held tight against the surface of the duct (the number and exact appearance of these objects varies a little from amachine to machine). Look carefully at these, and you'll find that one or two of them have a little reset button in the middle of them. Check again that the power is off, then give each of these buttons a gentle prod. With a bit of luck, one of them will make a sharp clicking sound - you have just reset a tripped thermal cutout.
Check whether this has worked by running the machine. If it has, then you need to find out what made it overheat in the first place and stop it happening again. This usually just means giving all the filters and ducts a thorough clean to remove lint that's restricting the airflow.
If the thermal cutouts aren't to blame, then the next suspect is the heating element. Diagnosing this is a bit more involved, though still managable as a DIY job. Check the cutouts first, then come back if you need help checking the element.
A.
Posted on Feb 24, 2008
  • 1122 Answers
SOURCE: Whirlpool dryer heat not working
DO YOU HAVE A METER? FIRST CHECK THE DOOR SWITCH,SECOND REMOVE THE BACK PANEL AND CHECK ALL FUSES AND THE HEATING ELEMENT,LET ME KNOW WHAT YOU FIND AND WE CAN GO FROM THERE-MIKE
Posted on Feb 26, 2009
protek480
  • 1723 Answers
SOURCE: whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Posted on Jul 12, 2009
  • 32 Answers
SOURCE: whirlpool dryer model LER3624jq0 has no heat but
They could get electricity but when the coils are broken into the will not heat. Diaphram is at AppliancePartsPros.com I dont actually know them but I found my parts there.
Posted on Oct 10, 2009
  • 396 Answers
SOURCE: dryer runs, no heat Whirlpool duet 9250
Most likely, it is the thermostat which controls the heating element. The Bios Thermostat will have two wires connected to a round disc which has a flange and screw holes to hold it next to the blower vent or the center of the drum. Use an ohm meter to see if it open or take it to an appliance parts store to have them check it for you. You may also see a thermal fuse and a high temperature cut-off thermostat which should not read open with an ohm meter. Any open thermostat will prevent the heater element from turning on. The part should be about $25.00.
Posted on Feb 15, 2010
Why my whirlpool duet dryer wont heat model wed8300sw1
Are the thermal fuses ok? If you're in the back of the machine clean out all the oose, lint, fluff or whatever that causes the heat build up.
May 07, 2014 | Whirlpool Dryers
Why wont whirlpool duet dryer model WED8300SW1 heat?
Is the dryer gas or electric? But you can also try cleaning the vent tube the pipe that goes outside also the pipe that goes into the dryer it's a good chance it's full of lint.
My gas dryer wont heat. Model whirlpool lgr4634bq1
Does the igniter click at all when it tries to start?
Oct 21, 2012 | Dryers
Electric dryer doesn't heat.
Probably a bad heating element. There are a few different styles, you'll just need to lookup your model number on an appliance parts website, find the right part, and then do a quick search on replacement. There are probably ten or fifteen websites that have instructions to replace heating elements.
Here's one where you can buy the part, the element is part number 17.
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Dryer-Parts/Whirlpool-Parts-LER3624EQ1/Whirlpool-Parts-81777.cfm
Jan 15, 2010 | Dryers
Whirlpool dryer model LER3624jq0 has no heat but spins and works fine besides that..fuses are good, the heat coils are getting electricity but just wont heat up.. seems like everything is workin fine just...
Oct 10, 2009 | Whirlpool Dryers
Whrilpool washer/dryer stack the dryer doesn't get hot
You will find that the drier wont get hot because the timer is not forwarding onto the heating part of the cycle. Possibly if you click one click at a time, you will possibly get to the heating part of the cycle but its not safe as it wont go any further. Install a new timer and you will be happier I'm sure.
Sep 28, 2009 | Dryers
Dryers Logo
54 people viewed this question
Top Dryers Experts
