Question about Krups BeerTender B95 Beverage Dispenser
Does the krups beer tender have a fuse or circuit breaker
Plugged in. Turned on, no lights. Over time it lost temperature
3 Suggested Answers
SOURCE: Our Krups Beer Tender B95 display started
Your power supply has gone bad. Mine did the same thing. Sent it to repair place (under warrenty) and it has been 2 months and it is still not back. If you can find another beertender for 100 it is cheaper to buy another OR JUST TRASH IT!!!! Obviously this thing is junk as there and 100's of the same postings of this problem.. fafe it... we got ripped off. Sad because I really liked it... when it worked
Posted on Jan 31, 2011
SOURCE: I have owned a Krups Beertender for about two years. It has been working fine. The unit thermostat light turned red about 24+ hours ago and mains on. The fan is working. The beer is warmer than usua
It could be the peltier or bad capacitors on the power supply.
http://www.fixya.com/support/t1554764-display_krups_beertender_stopped_working
If it is caps on power supply they are cheap.
Posted on Jul 28, 2012
Is the capacitor bad and also this other this other component?
On the top photo, the "D2" diode is probably bad. On the bottom photo, the three capacitors that show swelled tops are either bad or failing rapidly.
Dec 31, 2014 | Krups BeerTender B95 Beverage Dispenser
Krups wont turn on
Check circuit breakers more than likely one is tripped .check a gfci- outlets . A lot of times kitchen outlets are tied in to ground fault recepticles. Commonly called gfci 's. If it has a light on it that is lit up press reset button. If it clicks and stays lit it's bad and needs replaced.
May 26, 2014 | Krups Coffee Makers & Espresso Machines
Krups b100 does not get cold enough. How do i fix this
Maybe the beer inside is cold enough to drink, but the green led that indicates it's ok, doesn't light on. So the thermostat may be not operating well or the ambient temperature is too hot. My beertender B100 is operating without turning compressor off. The compressor never stops operating... even when external temperature is under 26 C... but the beer temperature is ok.
Oct 04, 2013 | Krups VB2158001K BEERTENDER B100
Can I use beer to tenderize my meat?
Beer is a great tenderize it has alpha acids and tannins so it effectly tenderizes the meat. It also adds flavour!
Jan 14, 2013 | Home
I have owned a Krups Beertender for about two years. It has been working fine. The unit thermostat light turned red about 24+ hours ago and mains on. The fan is working. The beer is warmer than usual. ...
Jul 21, 2012 | Krups BeerTender B95 Beverage Dispenser
Krups KM7005
Unfortunately, it seems that China is the only one manufacturing the thermal fuses and they are notoriously inaccurate, tough to find as replacement parts and most often they are spot-welded to the heating element's leads, something most owners can't accomplish.Soldering them isn't wise since they are located close enough to the heating element to cause solder to flow.
There is a type of barrier connector common in Europe, hard to find elsewhere, that uses screws to hold the wires to be brought together; one hole that goes through a metal channel and has screws mounted at 90 degrees so that each of the wires are held by one screw.I have replaced the thermal fuses this way with some ancient US made stock (once had reason to keep these on hand) that is rated for lower temperatures and therefore must be mounted slightly farther away from the heating element. I wouldn't do this to someone else's coffee maker since I cannot guarantee the effectiveness of the thermal fuses installed.
Do NOT decide to just jump the blown thermal fuse with a piece of copper wire. I know of one case this was done and the machine failed to shut down on time and a Formica counter was set ablaze.
Some cases of circuit breakers tripping may be those which combine a GFI (Ground Fault Interrupter) into the breaker and will trip if even a minor ground current is sensed and this can occur from moisture trapped inside the machine.This type is commonly found in newer homes on circuits located close to any exposed plumbing to prevent death by electrocution.
Feb 06, 2012 | Krups KM7000
My kenmore sid by side frige has lost all power the recepticle i use is fine.it's less than 2 yrs.old
Reset the circuit breaker or fuse and ensure the fuse has a 15 amp time-delay to provide enough power to the refrigerator.
Ensure the temperature control knob is turned past "0" and is set at a temperature cool enough to require motor function from the refrigerator.
Wait 20 minutes and check the power on the refrigerator again, as the unit may be in a defrost cycle, which may make it seem as if it was turned off.
if that doesn't work, and your sure you have power to the plug itself,, contact the searsdirect.com
they have an online chat repair
Jun 12, 2011 | Kenmore Side by Side Refrigerator
Our Krups Beer Tender B95 display started flickering on and off. We turned it off by the switch and back on. It continued flickering. We then unpluggedf it. When we plugged it back in, it totally shut...
Jan 30, 2011 | Krups BeerTender B95 Beverage Dispenser
Krups BeerTender B95 Beverage Dispenser Logo
69 people viewed this question
Top Krups Refrigerators Experts
Tom Chichester
Terry Hair
JonSnell Electronic
JonSnell Electronic
Are you a Krups Refrigerator Expert? Answer questions, earn points and help others
