Question about DeVilbiss Air Tools & Compressors
Impact wrench is not working
Connect compressor, pull trigger, wrench is not turning.
5 Suggested Answers
  • 5 Answers
SOURCE: Impact wrench never stops spinning!
you have a bad o-ring at the air inlet
Posted on Apr 25, 2009
rockitman187
  • 2559 Answers
SOURCE: 1/2' Impact wrench does not work.
Yes,Just look up a seal kit for your brand on google
Posted on Jun 01, 2009
john631068
  • 172 Answers
SOURCE: Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Posted on Nov 17, 2009
mister_b_65
  • 74 Answers
SOURCE: where do i get a replacement trigger, mine is
If your local Sears store can't help you, try looking to see if you have a Snap-On, Corn-well, or Matco tool distributor in your area. Many air tools are manufactured by companies who make tools for different distributors. I work in a shop, and have found that many of the tool trucks have parts that'll work on other brands of tools besides their own.
Posted on Dec 13, 2009
Fixing a trigger on an old impact wrench.
You will need to find a spring for the trigger, parts are hard to come by new unless it is a Snap-on or MAC brand.
Sep 07, 2016 | Impact Air Tools & Compressors
STUCK TRIGGER
The I.R. 2135Ti or TiMAX has some known issues with the trigger o-ring (item# 22A) swelling, the throttle valve (item# 28D) bending or breaking, and the throttle valve seal (item# 28E) wearing out or deteriorating. Procedure wise you should not be able to remove the trigger without first removing the inlet bushing assembly (item# 26) the reason is that the reverse valve (item# 24) keeps the throttle valve from tipping forward and releasing the trigger, there is a slot for the stem of the throttle valve to slide into.
Follow this link to the parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
When reassembling the tool first install the inlet bushing assembly and then install the trigger, make sure to lube the o-ring before inserting.
Oct 17, 2012 | Ingersoll Rand 2135Ti Air Impact Wrench
Crankshaft pulley r/r
Place the crankshaft pulley bolt removal tool over the end of the crankshaft bolt. Tool will hold the pulley in place while you apply torque to the bolt with an impact wrench. Start the air compressor by plugging it in and turn it on. Set the pressure of the compressor on the highest setting. Attach air hose on the air compressor to the air inlet and the locking mechanism using the quick-connect lock on the end of the air compressor hose. Set the impact wrench to turn counterclockwise. Spray the crankshaft bolt with penetrating oil. Make sure you soak the bolt head in oil so that it is easier for the wrench to remove. Secure the socket end of the wrench to the pulley bolt and pull the trigger on the impact wrench. You might need to reapply penetrating oil several times during this process to loosen the bolt up. Eventually, the bolt will come off 215 lbs torque, and simply stated righty tighty, lefty loosy. Hope this will assist you.
Dec 19, 2011 | 1991 Honda Accord
Nov 14, 2009 | Craftsman 1/2" Impact Wrench
Jun 01, 2009 | Campbell Hausfeld Air Tools & Compressors
No pressure when pulling trigger, trigger sticks in handle body
if air sound comes out when you press trigger your pressure regulator pin is stuck-oil gun and attach hose repeate until pin frees or remove pin and clean with brake kleaN oil and replace
May 31, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
Apr 16, 2009 | Impact Husky® 1/2" Wrench
Just blows air when trigger is pulled.
Dave The rotor is too tight on the plate. Tap shaft with fiber mallet to open the clearance
Apr 07, 2009 | Impact Ingersoll-Rand 1 Inch Heavy Duty...
My 1/2" CP air wrench just blows air thru when I pull the trigger
I have ran into this many times, even though you keep it oiled dirt can and will get inside. what you need to do is unscrew the 4 alen head bolts and pull the nose off. You will see a shaft that looks kind of like a crankshaft with 5 or 6 flat carbon fiber plates sitting loosely in groves around the shaft. pull those out and clean them with solvent and check them for damage or wear. clean the inside of the gun with solvent or brake cleaner, reassemble and it should work fine. If the plates need replaced then you should be able to order them from a tool supplier,and they are not that much.
Jan 17, 2009 | Chicago Pneumatic 1/2" Air Impact Wrench
Air Wrench Question
An impact wrench works in the manner suggested by the name of the tool: through the principle of impact. In order to understand how an electrical or air-powered impact wrench works, it helps to know first how a manually powered impact wrench operates. A manually powered impact wrench looks like a fat screwdriver; on the end where the screwdriver blade normally goes, you can snap on screwdriver bits or sockets.
Aug 27, 2008 | Ingersoll Rand 271 Super Duty 1 Inch...
Air Tools & Compressors Logo
53 people viewed this question
Top DeVilbiss Air Tools & Compressors Experts
JOHN LAPIER
ray gallant
Lawrence Oravetz
Are you a DeVilbiss Air Tool and Compressor Expert? Answer questions, earn points and help others
