Question about Earlex WD1000 Wet/Dry Vacuum
Needs new carbon brushes - Earlex WD1000 Wet/Dry Vacuum
Electrolux el 7020 Canister Vacuum shuts of continuously do i need to Change the Carbon Brushes
How old? If fairly new you should not need brushes, bad brushes would probably not allow the vacuum to run at all. Last time you changed filter? Sounds like the cover to the filter is not closing well enough. There's also possibility you have a clog in the wand or hose.
Mar 05, 2015 | Electrolux EL7020 Bagged Canister Vacuum
Motor carbon brushes
hi try potts in derby babbington lane ,very help full
Apr 08, 2013 | Sanyo Vacuums
How to install carbon brush
You have to open the case. First remove the transparent plastic on the side then you will see screws on the bottom part of the transparent plastic. Unscrew them and from there you will open the machine. Remove the rexair cover and unscrew the screw that attaches to the 2 carbon brush. When you remove the carbon brush you will see a spring and the copper wire at the end of the brush. remove it and put the new copper wire from the new carbon brush to the contact passing thru the middle of the spring. Then screw it back tightly.
Jan 30, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Motor smells hot after 5 minutes. Brand new exhaust filter turns black
First - stop using the machine! The black material in the exhaust filter is carbon dust from the carbon brushes in the motor. The fact that the motor quickly smells hot and is shedding so much carbon indicates that the carbon brushes are worn to their limit (or damaged). They need replacing. Don't use the machine again until the new carbon brushes are in place or you risk causing irreparable damage and will be in line for a costly new motor. Carbon brushes are usually not expensive but, depending on your expertise, you may need someone to fit them for you.
You don't tell us the make or model of your vacuum so that's about all I can say. Good luck.
Jan 23, 2010 | Vacuums
How to change carbon brushes
You need to know that very seldom will new carbon brushes alone `FIX`a motor in todays vacuums as they are higher RPM than those of 30 years ago.
On a salvageable motor a good rebuild procedure will generally include repacking bearings, cleaning suction fans and reseating new brushes with an abrasive seating stone at low speed with a motor run in device with variable voltage
That said, I have not done a HENRY in years but it likely will contain a generic AMTEK Lamb type motor as it is sold as more durable vac.
On a traditional vac motor, carbon brushes are removed by releasing a clamp over the brush. The brush holder will have either a flag terminal on it where the wiring will disconnect from the side, or a flat flag terminal which slides into a pocket on the carbon brush housing.
. If you are going to the trouble of replacing the brushes, remove and inspect the old ones for wear and chipping. Also inspect the commutator surface on the motor where the brushes contact. If there are any curved gaps between segments, or if the com is worn like an apple core , you need a motor complete.
If the motor has simply worn to the point where a brush has stuck or worn to nothing, you may be bale to reseat the new brushes, however any evidednce of BLUE sparks or noise is not a good sign . Best of luck. Post back if you need more help
Nov 01, 2009 | Henry Numatic "" Canister Vacuum
I NOTICED SPARKS INSIDE THE UNIT WHERE THE HANDLE ATTACHES TO THE MOTOR....NOW IT IS NOT WORKING WHAT CAN THIS BE?
DO NOT TRY TO TURN THE KIRBY ON ANYMORE BEFORE YOU GET THIS REPAIRED!!! Your Kirby needs carbon brushes and if you don't already need a new armature, the worn out brushes will destroy the armature that you have. Here is a guide that will help you get down to the carbon brushes to change them...
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
It is a guide to replace the power switch, but will give you the step-by-step to get down to the carbon brushes.
Hope this helps,
Marci
Jun 10, 2009 | Kirby Ultimate G Bagged Upright Vacuum
"CHANGING CARBON BRUSHES ON A DYSON VAC"
Solent Tools have a full range of Dyson brushes available. Tel 023 8057 8057. www.solenttools.co.uk
May 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Carbon motor brush source?
unfortunatly the only way you could purchase the carbon brushes is from a vacuum parts dealer directly. the brushes will most likely end up costing you close toth price of a new motor anyway. sometimes its best to just get a new motor as the newer designes rotate teh brush much faster for better cleaning.
Oct 25, 2008 | Filter Queen Majestic Canister Vacuum
How to change carbon brushes in Vax 2000
Bend back the three tabs and cut off the contact wire as close to the top tab as possible. You can then pull the brush (or what is left of it) out. The new brushes have a brass plate the same size as the brush opening. The connection wire that you cut away on the original brush is attached to this plate so you don't have to solder the connection. Push the new brush into the holder (you might have to file the carbon slightly to get it in). Then you have to compress the spring so that it all fits into the brush holder (this is difficult) once this is in keep the sping compressed with a small screw driver or other small tool, and bend the three tabs back over the brass plate to hold it in place. This is tricky but can be done.
Aug 31, 2008 | VAX Appliances Vax X5 Bagless Upright...
Good armature maybe needs new brushes
You can replace the carbon brushes and most repair shops should have them. Also tho, the armature could be causing the problem, if you put in new brushs and it still arcs badly, then the armature is bad.
Apr 16, 2008 | Kirby G4 Bagged Upright Vacuum
Earlex WD1000 Wet/Dry Vacuum Logo
23 people viewed this question
Top Earlex Vacuums Experts
JoeVacs
Are you an Earlex Vacuum Expert? Answer questions, earn points and help others
