Question about Razor 300001-SL Ground Force Go Kart
Razor crazy cart - Razor 300001-SL Ground Force Go Kart
Why doesn't it run?
Try battery first check with digi. volt ohm meter, but yes it could be module.
Jan 26, 2016 | Razor Crazy Cart Electric Ride On Pink
Remove crazy glue from glass
Crazy glue crystallizes when in cures; when it sticks on glass it can be scrapped with a sugar edge razor, or other sharp edge object.
Mar 08, 2015 | Cars & Trucks
Razor Scooter ground fOrce go cart wont go
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
Feb 07, 2015 | Razor E100 Electric Scooter
Razor ground force go cart
I don't think this would be a problem, as long as the wheels fit the axle properly, both in diameter, and length of shaft.
Aug 24, 2014 | Razor 300001-SL Ground Force Go Kart
Dull razor blades after moisturizing stripe wears off
Expensive replaceable cartridges are only made to offer 4-6 "good" shaves for most people. Sorry - that's the deal. You can strop cartridges (in on direction only) on denim and pick up maybe a dozen more - search youtube for examples. I finally gave up on carts and moved to a straight razor; a razor or two will last for a lifetime with good care. There IS a learning curve for safe use and maintenance procedures. Find a straight razor forum if you want great shaves and good advice on what to buy, what not to buy and how to be safe.
Double edged safety razors are also a very good alternative for better, smoother shaves and WAY less expensive blades. Same advice - find a razor forum to save money, buy right and avoid nicks.
Apr 16, 2014 | Health & Beauty
Replaced transformer
This go cart does not have reverse, so positive & negative wires must be switched.
Dec 01, 2013 | Razor 300001-SL Ground Force Go Kart
HOW TO REMOVE CRAZY GLUE FORM ARBORITE
I would try either:
a) a razor blade and hot soapy water
b) acetone (nail polish remover)
c) if there is alot of it and neither of the previous 2 solutions worked, you can buy superglue solvent
Dec 14, 2012 | Elmer's Instant Krazy Glue
My razor dune buggy won't drive
are you sure that the charger is putting out enough volts to charge the batteries? check the charger with a multimeter, then check the batteries with a multimeter, and viually inspect the batteries for bulging
Apr 28, 2012 | Razor Dune Runner 350 Go Cart
Razor Ground Force Go Kart will not work.
replace thumb tab throttle. part is $12.99 from razor. go to razor site to order. i had the same problem after my daughter drove it over a bumpy sidewalk.
Mar 05, 2009 | Razor 300001-SL Ground Force Go Kart
My razor v3m battery
display brigthness is a factor along with blue tooth try fully charging the battery for a long time
Jun 21, 2008 | Motorola Mobility RAZR V3
Razor 300001-SL Ground Force Go Kart Logo
146 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
