Question about Whirlpool (ET8FTEXSQ) Top Freezer Refrigerator
How do you remove the air duct from the back of a whirlpool gold bottom mount freezer back?
I am in the process of trying to remove the back inside panel in order to attempt to clear the frost drain. I haven't been able to find any other source of a freezer leak and its ruining the laminate flooring underneath. cant seem to get the duct off to remove the back panel. 4 screws are already removed and i see the screwdriver symbol and it shows a counterclockwise rotation but no dice thus far.
  • 159 Answers
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Posted on Aug 10, 2007
  • 1073 Answers
SOURCE: Whirlpool Top Mount Refridgerator is Leaking
the problem lies behind the freezer back wall panel, remove the panel, the ground (green) wire on the top left corner and the icemaker
all the ice build up under the evaperator will have to be removed, a good hair drier works well, direct the air at the center hole in the bottom of the metal panel all the ice out of the center hole will need to be melted out to be a success it will take a little time. you can pour some water down the hole and if you hear it going into the bottom drain pan then the tube is clear of ice.
Posted on Apr 10, 2008
  • 1462 Answers
SOURCE: Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Posted on Nov 17, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
Posted on Feb 11, 2009
jumptrout51
  • 3361 Answers
SOURCE: Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Posted on Feb 22, 2009
My whirlpool gold freezer is working but my fridge is warm I have an upper fridge and freezer is on bottom how can I fix it
all the machine does is the evaporator coil in the freezer gets cold,there's a fan in the freezer that blows the cold air from the freezer up into the fridge section and that's it,so if your fridge is warm you either have a bad evap fan motor or you could have a defrost problem,check to see if there's any ice or like snow on the back inside wall of the freezer,if so you have a defrost problem and you'll have to see what part is bad,if it is a defrost problem,you can shut the machine down or unplug it,take the food out of the freezer and if you can remove the back inside wall so you can melt out all the ice on the coil and air ducts,this will give you like 10 to 12 days to fix it or call someone in to fix it before the coil freezes up again,you can use a hair dryer to do this,or there could be a damper inside the top of the center back wall,you'll see slots in the top of the tower on the back wall,if there's a damper the damper door might be closed not letting any air in,next time send the full model number off of the fridge so whoever answers you can see what you have,if the freezer is on the bottom usually if you open the fridge door or the right french door,look up on the right wall near the ceiling and you should see a tag,if not there look on the other wall or ceiling they used to be on the right wall but on some of the newer models they moved the tag, nice guys lol.so open the freezer door,listen for the fan,if you don't hear the fan that could be your problem,check the back wall for frost,you could have a defrost issue or if there's ice on the back wall and the ceiling the door could have been left open,common problem with bottom mounts,if so if you google the model number you can find how to manually put the fridge into defrost,this turns the heater on in the freezer to melt the ice off of the coil,you can then get in there with a hair dryer and help melt it out,when you don't see any water dripping down and you can see it through the slots that are cut in the back wall of freezer your all set.the problem is the air ducts are frozen up and the air can't blow from the freezer and into the fridge.hope this helps you out but without a model number this is the best i can tell you.
Nov 23, 2017 | Whirlpool Refrigerators
How do i fix a dryer heating element
On most Whirlpool dryers, you need to remove the back panel. You will then see a square like duct work on the right side. The heating element is mounted inside the bottom of the duct work. A few screws and a couple of wires and it should come out.
Jul 01, 2015 | Whirlpool Dryers
My whirlpool gold refrig is icing on bottom of freezer. Is there any way to fix it without removing the back panel of the freezer?
You may need to manually defrost it, Even a frost free freezer can get frost. After you do that, make sure that you leave enough room for air to flow around.
Feb 11, 2015 | Whirlpool Refrigerators
My Whirlpool Gold Series Fridge is not cold in Fridge part, but is still working in freezer part. What might the remedy be?
Could be a few things. One could be a bad evaporator fan motor in the freezer section. The fan motor will only come on when the light switch is closed so make sure you hold down the light switch when you check it. Could be a defrost timer or defrost bimetal. You will know because you will have ice buildup on the back wall inside the freezer. Also could be icebuildup in the return air duct. They are located under the drawers in the refrigerator.
Oct 19, 2014 | Whirlpool Refrigerators
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
Frost accumulating in the freezer . Whirlpool Gold purchased two years ago
Sounds like an issue with your defrost circuit. Usually the defrost terminator. It is mounted on the coil behind the panel inside the freezer. There are two wires going to it. It is the size of a quarter around and maybe an inch thick. Good luck!
Apr 30, 2010 | Whirlpool GB9SHKXL Bottom Freezer...
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool fridge getting water from upper freezer compartment
well if you hat the freezer on top normaly air leaks inside freezer through the drain tube, that air turns into condensation and creates a ice and cloges your drain. now water can drain down to pan everytime ref goes into defrost , and water leaks to bottom section to air ducts and air returns. there are several ways to solve this problem the cheapeste way is to unplug refrigerator for 2 days then plug back up and it should go back to normal another way is to install a heat probe on your drain attached to your defrost heater , and add a grommet on drain tube that will let water drain but it will keep air out and that will solve your problem.
Oct 12, 2008 | Whirlpool Refrigerators
Whirlpool Gold GS6NBEXRB01 - While Auto-Defrosting, the water drips into freezer from inside Grill
you have a frozen or blocked defrost drain behind the back panel with the vents in it remove the panel and clear the drain at the bottom in the silver pan
Jun 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool (ET8FTEXSQ) Top Freezer Refrigerator Logo
35 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
