I have a kenmore Elite #79629002010 top loader the top will not open and the clothing is molding in it
The power does not go on so I cannot open it
SOURCE: smells of mildew and so do clothes
There is another product out there that seems to work real well.... it is called "AFFRESH" and it is for He front load washers... Its available at Lowes for about $6.50
Posted on May 29, 2008
  • 60 Answers
SOURCE: Kenmore elite washer smells
You are probably using too much soap and softner. You only need about 1 Tablespoon of each for a full load with a front load machine. Run it with nothing it in except bleach. If you see bubbles inside that means there's left over soap in the tub. Keep running it empty (with bleach) until you don't see bubbles anymore then start using less soap.
Posted on Jul 30, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Clothes come out super wet
Drive motor failure, CCU or Motor control failure. To ceck this look at your owners manual and from then test the parts with a multi meter. To keep from spending money you can unplug your machine for 15 to 30 minutes, plug it back in and sometimes that will clear the code and everything will work just fine. Also some parts are covered under the 5 year warranty so make sure about that also
Posted on Apr 17, 2009
  • 51 Answers
SOURCE: kenmore elite calypso wash motion top loader won t
Unplug the unit and let it sit unplugged for 30 minutes. There is a power filter on the AC input line and sometimes power surges can cause it to need to bleed off the voltage from capacitors. There is a test procedure to see if the filter needs to be replaced but so far every time this has happened to our Calpyso, we pull the plug for a bit and the washer recovers.
There isn't enough space on this text box to post the removal & replacement procedure for the line filter, but you can find it at www.pcappliancerepair.com and look up the part # on the Sears Parts Direct site for your model # specifically.
Posted on Oct 03, 2009
  • 572 Answers
SOURCE: Machine flashes LD
ld means lond drain. clear the drain from the pump to end
Posted on Feb 06, 2010
Kenmore washer mold smell issue
front loader of top loader? For front loaders you need to dry around the front gasket and leave the door open 24 hours after each wash.
Put a couple of towels in the machine and add a full box of Arm and Hammer Baking Soda and do a 90' boil wash. Clean towels and the smell gone.
Jul 17, 2016 | Kenmore Washing Machines
How do i get rid of mold in my washer
If top load, run a washer full long cycle with out clothes and a full cup of Clorox. If a front loader, do the same thing, but then open door after the full cycle is complete. Front loaders are sealed and there is nowhere for the moisture to go..
Jan 22, 2014 | Kenmore Washing Machines
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
FOUL, MUSTY, MOLDY ODOR THAT GETS INTO CLOTHES. CLOTHES SMELL BAD
If this is a Kenmore Elite front loader, such as the one you posted this question under, the odors generally come from mold, mildew, and/or debris in the drainage system. The following link explains some preventive measures you can try that will minmize odor problems and prevent the develpment of harmful mold and mildew:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
If you have a serious mold or mildew problem on the door bellow and cleaning doesn't help, you may need to replace the seal to get rid of the problem. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this information is helpful to you.
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite calypso top loader clothes still wet after spin
more than likely the machine has a bad clutch or motor.. in most cases it is cheaper to just buy another top loader.
Mar 06, 2009 | Kenmore 24032\24036 Top Load Washer
No Power and will not open.
Try unplugging the machine for 10 minutes. A lot of times the computer will reset and function normal. At least you can most likely get it to unlock to get your clothes off.
Nov 14, 2008 | Kenmore 24032\24036 Top Load Washer
Stinky Washer
We had the same problem with our front loader. (after only a year) We ran a load on "sanitary" setting with bleach. After that we leave the door open after EVERY load. That has fixed our problem
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
Top Washing Machines Experts
