Question about GE WJSE3110A Top Load Washer
I have a GE WJSE3110AOAA clothes washer that doesn´t work at all, does anyone know wher to find some circuit board help.?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my GE Microwave JVM1860 does
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Feb 22, 2011
Everything on my GE washer works but the agitator.It barely moves.
New design to be gentler on clothing agitator moves 180 degrees 1 direction and then back 180 degrees
Feb 17, 2010 | GE WBSR3140DW Top Load Washer
GE top loading washing machine (WBSE2090A0WW) stops spinning
it sounds like you know how to remove the frount panal,remove the frount panal.put unit in spin,look to see if belt is turning,if it is not than you have a bad cluch.
Dec 29, 2009 | GE Profile WPRE6100G Top Load Washer
Does not agitate or spin. model number WPRE6100G0WT Pump works fine. Lid switch is okay and power to motor. Fuse on nuetral is also good. Suspect control circuit board or inverter at the motor. Can...
Is motor running? Remove cabinet and jump the lid switch with a small piece of wire. Put washer into cycle and run. Does the motor work? No- I would guess you have a bum circuit board or a short before the motor. If this is a direct drive, you probably have a slipping clutch, which is an easy fix. Let us know.
Aug 21, 2009 | GE Profile WPRE6100G Top Load Washer
Final Spin
could be a clogged water pump. check the filter/pump for dirt and small items, socks, pins, coins,
tnx 4 using fixya,
drcool
Oct 11, 2008 | GE WBSE3120B Top Load Washer
Kenmore washer
This is a known problem with the Oasis. It is caused by a bad relay on the Interface Control Board inside the console. Unfortunately, the "cure" for the problem is the replace the board and/or the wire harness that connects the console to the Main Control Board underneath the console. If you attempt to defeat the sound on the circuit card you could potentially damage it to the point where it doesn't work at all. The circuit board usually runs about $120. The only inexpensive alternative is to leave the room and shut the door behind you. That way you won't have to deal with the annoying beeping.
Aug 21, 2007 | Kenmore Oasis HE 27082 Top Load Washer
GE WJSE3110A Top Load Washer Logo
44 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
