Question about Fitness Quest Integrity 3000 Air Rower
Looking for a drive strap for the integrity 3000 air rower
Rowing machine belt
If there is a number printed on the belt you can search for the same number here: www.beltpalace.com/fitnessbelts.html
You may have to include the rib count if the belt has many small grooves. For a 6 rib belt, the part would look like "470J 6" or "6 PJ1070".
May 24, 2014 | Fitness Quest Integrity 3000 Air Rower
Broken cord
Where can i get a replacement cord belt for the air rower, its frayed and snapped?
Mar 31, 2014 | Fitness Quest Integrity 3000 Air Rower
Squeaking
I am in the same boat, currently looking for an answer on this one. It is a really abnoxious squeak. Tried WD-40 but no luck. Not sure where the problem is even coming from.
Nov 11, 2011 | RTO Stamina Ats 1400 Air Rower
I am not getting any resistance from my Integrity 3000 rower. The fan does not make a noise when I pull.
Your chain is stuck on the bearing and not on the gear. Its stuck on the rod holding the gear. See the thing that looks like a bicycle chain that leleads from the pull handle to the black cover next to the fan? Well under that black cover is a gear that holds the bicycle chain. To get to it, you need a screwdriver. Take off the cover and you need to pull the bar vertical to the air and you need to realign the chain. Your welcome! Source: same problem
Sep 17, 2011 | Fitness Quest Integrity 3000 Air Rower
How to assemble my machine
You may have to call Fitness quest to the manual for this unit
Corporate Headquarters
1400 Raff Road SW
Canton, OH 44750
Phone: 1-800-321-9236
Email: Customer Support
Fax: 1-330-479-9213 between the hours of 8:30 a.m. and 6:00 p.m eastern standard time,
Monday through Friday (excluding holidays)
Aug 14, 2010 | Fitness Quest Integrity 3000 Air Rower
The chain does not return smoothly. The chain does not retract. I don't have a manual to see if the machine is set up correctly.
A return spring or cord is not functioning or broken and the chain sprocket assembly bearing may have become defective or more likely needs lubrication. I would try contacting this company since they sold the product.Fitness Quest Corporate Headquarters
1400 Raff Road SW
Canton, OH 44750
May 20, 2010 | Fitness Quest Integrity 3000 Air Rower
Reebok fusion rower rev 11401 - how do i get it to see my polar heart rate monitor watch
I had cause to strip the covers off my rower now i find the strap does not recoil as supposed what have i done wrong with the reassembly...please...thx.its a reebok edge/fusion.
Sep 23, 2009 | Reebok Exercise & Fitness
My integrity air 3000 has a elastic like cord attached to the underside to the chain. The elastic cord is now unraveling. Where would I get it repaired? I live in Columbia, Missouri. Thanks, Patti O.
Call Fitness Qwest at 800 321-9236 for the part. They will need the serial number of the machine (on the back stand underneath. All of the parts are easy to replace. It is an easy machine to work on.
Jul 05, 2009 | Fitness Quest Integrity 3000 Air Rower
Where do you find replacement parts?
Can i buy a replacement return spring fr a proteus rower serial number GM013704
May 14, 2009 | Fitness Quest Integrity 3000 Air Rower
Fluidrower strap does not recoil.
Probably is the one way bearing broken. You can order one at your agent.
Regards,
First Degree Fitness
Dec 29, 2008 | Neptune First Degree Fitness Fluid Rower...
Fitness Quest Integrity 3000 Air Rower Logo
Top Fitness Quest Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Fitness Quest Exercise and Fitnes Expert? Answer questions, earn points and help others
