Question about Dell Office Equipment & Supplies
My Dell Printer Model 1720dn won't let me do "double sided" printing from my MacPro 3.1 with Mavericks OS, Dell has no drivers for Mavericks
Dell Printer 1720dn won't let me do "double sided" printing with my MacPro running Mavericks. Dell has no print driver for Mavericks, only for Lion.
leroyal
  • 2120 Answers
SOURCE: Double-sided printing on HP Laserjet 3330
Reinstall the driver..
Posted on Mar 05, 2009
  • 15 Answers
SOURCE: HP 3100 LaserJet All-in-one Print Driver for Vista OS
It doesn't work in share mode either...It prints the pages incorrectly. I have the hp3100 connected to my xp pc and my vista laptop connects to it via printer sharing on my network. the xp prints fine but the vista doesn't print ok due to lack of driver support for it.
I have to resort to print to pdf and then take the pdf to my xp for printing. Its a half *** solution but if anybody out there made his/her own driver please post.
Posted on Aug 02, 2009
  • 7 Answers
SOURCE: How do I print double-sided automatically? HP Color LaserJet 2605
Go into the control panel, select the printer, select printing preferences, select finishing, put a checkmark in box where it says "print both sides"
Posted on Oct 09, 2009
SOURCE: My Dell 1720dn constantly has paper jams. A
here's one for you. if it is jamming with one sheet almost out (the trailing edges is just out of the fuser. it will also jam the same way everytime. you might try a different brand toner cartridge. I have beening fixing several with this.
Posted on Mar 30, 2010
  • 11800 Answers
SOURCE: I have upgraded the operating
Lion has just appeared and because Apple has never divulged its characteristics to all the other hardware manufacturers, they didn't had enough time to design new drivers. Unfortunately your printer is an very old model that hasn't had new drivers for OSX since Panther, which means that the possibility of a new driver for Lion is extremely remote.
So you are now left with just 2 options:
1 - you downgrade your Mac to the previous version of OSX
or
2 - you get a new printer.
Posted on Aug 20, 2011
5mm vertical gap dell 1720dn
Any time an imaging drum is replaced on a 1700, 1710, or 1720 model dell laser printer, you must reset
the photoconductor count. The following procedure illustrates how this is done:
1. Open the front access cover
2. Press and HOLD the Cancel Button (Red X)
3. When you see the LED's 'Chase' turn the printer off
4. Close the access cover, and turn the printer back on
5. Press the Continue Button (Green Triangle) to print a settings report
6. Under the section 'Cartridge Information', locate the item 'PHOTOCONDUCTOR COUNT=0K' indicating 'Zero Thousands'.
s now been reset, and you should now be able to print now ok
May 06, 2014 | Dell 1720dn Laser Printer
Printer problem with OS X 10.9 Mavericks
THE SAMSUNG CLP-310 is fully supported by Mac OS X 10.9 Mavericks. The printer driver (like all nowadays) is supplied by Apple not the manufacturer. If you installed drivers/software from a disk, you need to put that disk back in and run the uninstaller. Be sure the printer is removed from the printer list in the Printing system prerefernce pane and then unplug and replug in the printer. If it does not show up automatically you may need to add it manually in the system preferences window (no big deal.)
Nov 22, 2013 | Samsung CLP-310 Series
1720dn Laser Printer: printer offline. unable to set online....
I Open my browser....I signed in to my router as administrator ....
Mine is 192.168.1.1 ....
I went to status in my router ....
Then to local network ....
Then to DHCP Clients Table ....
This is how I found what printer address the was.... Then I typed the printer ip address into my browser
Mine happened to be 192.168.1.105 ....
Yours will probably be different....That got me to the 1720dn printer menu ....I clicked on Configuration ....
I clicked on Print Server Settings
I clicked on TCP/IP
I clicked on Set static IP address.
I changed IP address from 192.168.1.105 To 192.168.1.125
and Submit....Now you can get to the printer menu at 192.168.1.125
Go to run....
Printers & Faxes
Right click on Dell laser printer 1720dn
Properties. Ports ....
Add port ....
Double click on Dell Enhanced TCP/IP ....
I named the port My dell laser 1720 dn....Where it said enter a single IP address or host name I entered the new address 192.168.1.125
the clicked OK ....
Properties....Ports
Choose your new port ....
May 06, 2010 | Dell 1720dn Laser Printer
Dell 1720 printer prints junk first page with only ?Z@ troofpaN.
This is a issue with the printer drive that windows is holding, not the printer. To Un-install your printer drive the correct way, goto add/remove programs, and un-install the printer there, then open up your printer control panel and right click where there is no printer. In the right click menu click server properties, then click the drivers tab, then remove the 1720/1720dn drivers there. A system restart will be necessary in most cases before it will let you remove the drivers(the Microsoft print spooler is to blame here for that). If this still doesn't work for you, then install a hp laserjet 4 driver and see if it does the same thing. if not, then it is something with the driver/spooler, if so, then it is the MCU of the printer, and you might want to look at buying a new printer.
Jun 29, 2009 | Dell 1720dn Laser Printer
Dell 1720 flashinf replace drum- error.
The second link was the helpful information. Also, to cut through all of that --
If you need to reset the counter:
1. Remove drum kit with toner
2. Make sure all print jobs are flushed otherwise whatever has been sent and not printed will come spewing out.
3. Hold down CANCEL Button until all lights flash through.
4. Slide the drum kit and toner properly into the Printer.
done.
Mar 03, 2009 | Dell 1720dn Laser Printer
1720dn error light will not reset
Follow this link to a previous FixYa post about this error and the suggested solution.
Feb 23, 2009 | Dell 1720dn Laser Printer
New secondary tray not recognized on vista.
Dell Laser Print 1720 dn Properties window. Click on the last tab called install options. Click the ask printer button. This should update the print driver with the add on drawer.
Oct 30, 2008 | Dell 1720dn Laser Printer
1720dn dell
Normally to fix a printer that is printing gibberish, uninstalling and reinstalling the print drivers will fix this issue. Another thing that can contribute to gibberish print is using a USB cable that is too long.
With this particular problem (prints Zen), one solve is to uninstall any Dell toner management software. This is particularly true if you are running Vista and hooked up by USB. To uninstall the toner management software (Vista OS), go to control panel>programs>programs and feature>uninstall a program. From this list choose Dell software, choose a customized uninstall, and then choose anything that has to do with Dell toner management.
Sep 15, 2008 | Dell 1720dn Laser Printer
New Intel MacPro + Epson SP R1800 printer + OSX 10.5.2 = Nightmare.
I managed to solve this problem by, probably, doing what I should've done in the first place: Deleting the printer from the print queue and starting again from scratch.
I read the following instructions from a message from Epson and it pointed me in the right direction. It sounds obvious now, but when you think you've tried everything and you've started to pull your hair out, you can overlook what is staring you in the face.
Message from Epson:
If your output is faint or if the driver settings and/or features are
missing, your system may have automatically added the printer using the
Gutenprint driver. Many Epson drivers are provided with Leopard but the
driver for your printer needs to be downloaded from the Epson website.
Determine Which Driver is Currently Being Used
1. Click on the Apple icon in the upper left corner of the Finder and open
System Preferences.
2. In the System Preferences window, click on Print & Fax.
3. In the list of printers on the left side of the Print & Fax window,
click once on your Epson printer to select it.
4. Check the name of the driver being used; it is displayed in the center
of the Print & Fax window next to “Kind”.
5. If the driver name displayed next to “Kind” is Gutenprint, the incorrect
driver is being used. Follow the steps in the next section to select the
correct driver.
Selecting the Correct Driver
1. Turn off the printer.
2. Delete the print queue and remove the printer from Print & Fax by
clicking on the minus button under the list of printers. Click OK to
confirm the removal.
3. Go to the Epson support website (www.epson.com/support).
4. Select your product model and download the driver for OS X 10.5 Leopard
operating system.
5. Double-click the downloaded file and follow the on-screen instructions
to install the printer driver.
6. Click on the Apple icon in the upper left corner of the Finder and open
System Preferences.
The message ended there.
If anyone out there is having a similar problem to me, then I hope this thread helps.
All the best. logan
Mar 02, 2008 | Epson Stylus Photo R1800 InkJet Printer
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
