Question about Lexmark Marknet N7000e 1 USB Port 10100 Ethernet Connectivity Technology Wired
Lexmark Marknet N7000e 1 USB Port 10100 Ethernet Connectivity trouble
The port to which the printer is connected is not supported. Check the port
I'm assuming you are using a USB connection, not a Ethernet connection.
Try a different USB port (preferably in the REAR of the computer, not the front). It's not unusual to have 1 or 2 poorly-performing (low power) ports on a PC; some printers don't like those.
If you have a really old computer, it may have ancient USB type "1" (slow) ports instead of the newer 2.0 or 3.0 USB type. Some printers don't like old USB 1 ports, but it is not supposed to matter.
If all else fails, try another USB cord, or a shorter one. Some printers don't work well with cords longer than 4 feet, and USB cords can go bad.
Or, try the printer on another computer. If the same USB cord works fine there, YOUR computer has the problem (probably a USB port or USB driver issue).
Are you having issues with other USB devices? If so, it may be a Windows driver issue.
Good luck. If no help, post your exact printer model # here, or try contacting Lexmark.com support
Dec 02, 2013 | Lexmark All-in-One Printer with PictBridge
I recently purchased a new pc hp2009m and the cord on my lexmark e250dn does not fit my pc how can i adapt please advise. Colin
This printer has three standard ports: bi-directional parallel, USB, and ethernet (RJ-45). Most likely your previous computer had a parallel port. The simplest solution is to get a USB cable (Male type A to Male type B - 6' or less in length is recommended.) Install the software on the computer then connect the cable to the port on the back of the printer and to the computer (the square end goes to the printer and the rectangle fits the computer). The USB port is in the same area on the left side of the back of the printer as the parallel port.
Alternatively you could get a network switch and connect the printer as a networked printer. The ethernet port is near the middle of the back of the printer.
http://support.lexmark.com/index?page=recommendedDownloads&locale=EN&productCode=LEXMARK_E250D&segment=DOWNLOAD&userlocale=EN_US#1 has the software and drivers for support OS versions.
I hope this helps.
(Getting a bidirectional parallel to USB adapter is cludgy when you have a USB port available.)
Jul 01, 2010 | Lexmark E250dn Laser Printer
Lenovo WinXP - Ethernet port issue
Hi. Try to check the steps as give below.
  1. Check the ethernet port with other spare wire if you have to check if it is a wire problem or if it is itself your ethernet port.
  2. Try to connect your ethernet port directly to the router to make sure ethernet port is working and there is no connectivity issue with the switch.
  3. Try to check the System BIOS settings and see if it is not disabled from there.
  4. Lastly download any free Live OS of Linux and boot your computer using it. See if the ethernet card is working or not.
Steps from 1-3 is for checking physical connectivity of the ethernet port and the last step is for checking OS issue. If network card do not work with Live OS as well, you can directly come to conclusion that its ethernet card that is not working properly and you need to get is repaired.
Cheers!
Apr 14, 2010 | Lenovo Thinkpad T60 Notebook
Network card, Token Ring fitted, what card do I need for ethernet?
You will need to use Lexmark's MarkNet N7002e print server.
Check this link:
http://www.lexmark.com/lexmark/product/home/500/0,6970,204816596_653399458_253501940_en,00.html?tabId=7
Oct 16, 2009 | Lexmark Optra S 1255 Laser Printer
WHAT KIND OF WIRES DO WE NEED TO HOKUP A LEXMARK X3350 ALL IN ONE PRINTER.
Standard Ports USB Compatible with USB 2.0 Specification (Type B)
Optional Network Ports Lexmark N4000e Fast Ethernet (Print Only)
Lexmark N4050e 802.11g Wireless Print Server (Print Only)
According to:
http://www.lexmark.com/lexmark/product/home/277/0,6970,204816596_653399443_473191701_en,00.html?tabId=1
Sep 10, 2009 | Lexmark X3350 All-In-One InkJet Printer
Plugging printer in
Your printer comes with two interface, USB and Network (Ethernet). The USB is standard port provided. Ethernet is optional.
You must connect the USB cable provided to USB port in your PC.
If your PC does not have USB port, then you need to purchase USB extension for your PC. However, older PC which does not have USB normally running old Operating System that does not support USB either. So, better replace your PC, if you want to use the printer.
Regards,
Dapid Candra
Dec 08, 2008 | Lexmark X5470 All-In-One InkJet Printer
LexMArk Marknet 700Oe: Booting problem
hmmm...ok..you'll need to reinstall the server software, where those reside..
Jun 15, 2008 | Lexmark MarkNet N7000e (1 USB port) 10/100...
Instsll the switch
You will find the manual here:
http://www.dynexproducts.com/pc-185-4-dynex-5-port-10100-ethernet-switch.aspx
Usualy this type of device is very simple to install.
Feb 16, 2008 | Dynex 5 Port 10/100 Ethernet Switch...
Old IP address
You can reset the MarkNet X2000 to factory defaults - which includes resetting the IP address to 0.0.0.0 like this:
1. Press and hold the Test button until all four lights stay lit simultaneously, then release the Test button.
2. When #3 and #4 lights light simultaneously, press and release #1 (the Menu button).
3. When #3 lights press and release #1 (the Menu button).
4. At this point the X2000 print server has been restored to the factory default settings and should have an IP address of 0.0.0.0.
-John
Feb 06, 2008 | Lexmark Refurbished MARKNET X2000 SERIES...
Lexmark Marknet N7000e 1 USB Port 10100 Ethernet Connectivity Technology Wired Logo
19 people viewed this question
Top Lexmark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Robert Monigold
Robert Monigold
micky dee
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
