Question about GE Dishwashers
Both Spray arms not spinning
I have a nautilus Gsd3230f00ww dishwasher. I noticed that it didn't clean any of the dishes in the washer the last time we ran it, so I ran it again and the results were the same. I took everything out and checked it out and both the top and bottom spray arms are not spinning. There is water coming through them, but no movement out of either arm. Any suggestions??
    Problem Solver:
  • 9 Answers
Try removing both top and bottom spray arms some just pull off some unscrew,check the holes for any blockages seeds and rice tend to get stuck in them if plates are'nt rinsed properly, place under running tap, hook out with safety pin if neccesary
Posted on May 18, 2009
Makes noise during wash cicles and dishes are not cleaned
Hi Kenneth Cho - I will suggest verifying that there is enough water pressure coming into the unit. Is the unit making a grinding noise? If it is, then the dishwasher seems to have a defective drain motor. When was the last time the filter was cleaned? Do you noticed if the spray arm will rotate freely or if it is damaged? If so, you might have to remove and replace the spray arm assemblies. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
Nov 24, 2012 | Frigidaire FGHD2433KF Builtin Dishwasher
Dishes arent clean and alot of the soap remains in dispenser after cycle is complete
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 13, 2011 | GE Nautilus 24" Built-in Dishwasher
Do it have a filter to clean out dishes are sometime dirty like it not cleaning them
Dishwasher
How to Buy
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 22, 2011 | GE 25 in. Nautilus GSC3400J Free-standing...
The dishwasher is not cleaning the dishes properly, it has a build up all the time, such as hard water, or like the detergant is getting caked on the dirty dishes and it is not cleaning the dishes properly...
Dishwasher
How to Buy
heatman101
Jan 24, 2011 | GE Nautilus 24" Built-in Dishwasher
The dishes are not getting clean. There's a white film that remains after washing. Also, at the bottom of the washer and behind a screen filter in the back there seems to be a deposit build up.
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Jan 23, 2011 | GE Nautilus 24" Built-in Dishwasher
Dishwasher leaves a grit on the dishes
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
heatman101
Nov 04, 2010 | GE Nautilus 24" Built-in Dishwasher
Our newer dishwasher does not clean the dishes presently. The water heats up, and drains properly, but I noticed the sprayer nozzles are not spinning when I open the dishwasher.
Try manually rotating the spray arm. Check the orifices & clean if clogged.
After loading the dishes check every time before closing the door for free rotation of the spray arm.
Apr 01, 2010 | KitchenAid Architect? II U SERIES KUDS03ST...
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Sep 06, 2008 | GE Nautilus 24" Built-in Dishwasher
Wont clean dishes
Check to see if the Upper and lower spin arms rotate easy .. check to see if there is anything blocking them.. also check the venturi assembly (the tower is in the center of the lower spray arm} As it is what supplies the upper spay arm. let me know if this helps?
Mar 06, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwashers Logo
264 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
