Question about Toshiba Satellite 1405-S151 Notebook
I have a toshiba 1405 laptop it immediately goes to trouble shoot page, then wont load under any of the choices there. Then says use recovery disc. I inserted disc nothing happens
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Go into the BIOS by pressing F2 and make sure the cd-rom is the first boot device in the list. Save the changes and exit, it should then boot up off of the recovery disc.
Error code F3-F100-0004
I suspect, you have been trying to restore to factory settings. This does appear to be a common problem with Toshiba Satellites. You should always make recovery discs if they are not supplied with the PC, a lesson you will now have learned.
You have two choices, you can either contact Toshiba and see if it is possible to purchase a set of Recovery Disks for you particular laptop. Or, you borrow (as you have already thought of) a Windows 7 OS disc. Keep in mind this disc must be the same version of Windows 7 that is written on your Product Key sticker. This will probably be stuck underneath the laptop. If you try to use a different version your product key will not work.
If you can get the discs from Toshiba this will save you the time and trouble of having to download and install all the drivers that you need for a clean install as they will be included on the discs. Hope this helps.
Jan 08, 2013 | Toshiba Computers & Internet
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
Recovery disc for my laptop
You should be able to get a recovery CD for your model laptop from Toshiba.
You can download therecovery disc and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Apr 03, 2012 | Toshiba Computers & Internet
How do you system restore a Toshiba Satellite laptop to its original factory settings?
Are able to get the system to load, that is get everything up on the desktop? If you can most Toshiba systems have a disc creator for making your own copy of the restore software. If you can't get to either the disc creator or a full system restore. You may have to purchase the recovery disc directly through Toshiba.
Mar 30, 2012 | Toshiba Satellite U405-S2824 PC Notebook
My toshiba laptop satellite A55-S326 wont boot. Only can use the escape key then go into bios but still doesn't boot. Tried my recovery disc & it goes thru the instal but then still goes to a blank...
Your install discs are bad. Please don't shoot the messenger. Call Toshiba for new discs. Here is the number (it took me 30 minutes to find this. Please give me a 4-thumbs-up rating. If you don't, I spent time away from family for free).
(800) 457-7777 (toll-free)
Sep 24, 2011 | Toshiba Satellite A55-S326 Notebook
I want to reset it
@lslchrisorei
Toshiba laptops have a built-in recovery mode on the system wherein you don't need to use a disc to restore it to factory default (if that's what you mean by "I want to reset it". The hotkey for the recovery is the 0 key (don't use the key on the numpad). To activate it, you need to turn the computer off, then you need to hold the 0 key then turn the computer back ON. If you hear a continuous beep, you can let go of the key and It will then say "Windows is loading files" and will proceed with System Recovery. If this doesn't work, that means that this computer doesn't have the hidden partition for you to restore the unit to factory defaults (either it's faulty or it's not there) and you need to order the recovery discs from Toshiba at 1-800-457-7777 (for US) and for Canada, it's 1-800-663-0378.
If you're still under warranty, they'll give it to you for free.
Cheers
Sep 05, 2011 | Toshiba Satellite L305D-S5874 Laptop
Recovery disc wont work
I believe the only way to reset the password on those is to unhook the tiny battery... cmos battery it's called .... looks like a watch battery and isn't always easily accessable on a laptop
Dec 01, 2008 | Toshiba Satellite A215-S7422 Notebook
Window error recovery
hiiiiiiiii ther
how r u ??
u have OS problem u need to reinstal teh OS
and if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 25, 2008 | Acer Aspire 3100-1405 Notebook
Want a manual
You can download user guide/ manual here:
Toshiba Satellite 1405-S151 manual
After downloading this PDF file, open it and click the print option. Then, a dialog box will appear, in which you can select how many pages or which page to print.
Thank You
Sep 03, 2007 | Toshiba Satellite 1405-S151 Notebook
Toshiba Satellite 1405-S151 Notebook Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
