Question about Weber Genesis E-310 Gas Grill
Trying to adjust doors on Genesis 310 gas grill...Was assembled when we purchased it and I don't have assembly directions. Looking for help...Thanks!
  • 63 Answers
SOURCE: low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
Posted on Mar 14, 2009
  • 60 Answers
SOURCE: I had my Weber Genesis e310 assembled. They
you have to convert to ng call me at 469-774-5561
Posted on Aug 15, 2009
SOURCE: Weber won't get very hot
Safety valve needs reset.
  • Close the LP tank valve
  • Turn all burner control knobs to the OFF position
  • Open the grill lid
  • Turn the LP tank valve until it is completely open
  • Wait several seconds
  • Turn the front burner to the HI/Start position
  • Press the igniter until the burner is lit.
  • Turn remaining burners to High
  • Close the lid.
  • The grill should preheat to 500-550 degrees in 10-15 minutes
I called Weber and the rep walked me through the reset. All grills made after 1996 have this bypass valve.
Posted on Aug 31, 2009
  • 91 Answers
SOURCE: what is the best way to clean the grill?
use a good wire brush on the burners each time you use it before and after cooking. every season take the grill grates and flare reducers out and clean them well with a wire brush and or steel wool and clean out any residue in side the grill. make sure the grease catcher gets cleaned often as needed. blow out the gas manifolds with air in the spring to remove spider webs or insect webs etc. this should keep your grill working well for 10-15 years. replace the grates or flare plates when needed.also lightly clean the burners when you have the grill taken apart with steel woll then blow them out as well to keep all the openings clear. happy grilling.
Posted on May 30, 2010
heatman101
  • 43501 Answers
SOURCE: I have a new Weber Genesis E-310 Liquid Propane
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 06, 2010
Testimonial: "Thanks for the great hint. This solved my problem."
Assembly manual weber 310
i am having trouble lining the body of Weber Genesis 310 to the holes on cart sides. they seem to be off 3/8" towards front of grill. Could their spec be off or assembled incorrectly. I have gone over instructions several times & can't see where I went wrong.
Dec 23, 2011 | Weber Genesis E-310 Gas Grill
Hooked up proane tank used once then no flame on grill. There is propane in the tank but no propane flows out of it either when hooked up to the grill or when opening the valve directly on the tank. This...
The valve on the tank has an internal valve that will not allow you to release propane into the atmosphere. It must be connected to a regulator line in order to open.
It sounds like your regulator has failed. Remove the regulator assembly, inspect it carefully for blockage or hose kinks. If there none, try replacing the regulator assembly.
Gary
Sep 24, 2011 | Weber Genesis E-310 Gas Grill
The igniter box inside the grill is rusting and disintegrating. I bought the Weber igniter kit at Home Depot, but it has a red push-button, and I can't see how to begin replacing the igniter under ...
I have provided 2 links for you. One is the Assembly Manual for the Genesis B 330
and the other is the Owners Manual. Both should prove invaluable to you, in replacing the Ignitor Button. You can download and print each manual for future reference.
Assembly Manual
http://help.weber.com/manuals/pdf_files_2011/Gas/Genesis%20ES%20Series%202007newer/AssemblyInstructions/Genesis_310320330_LPng_AssemblyInstrctns_56507_022811.pdf
Owner's Manual
http://help.weber.com/manuals/pdf_files_2011/Gas/Genesis%20ES%20Series%202007newer/OwnersGuides/Genesis_320330_LP_OwnersGuide_56508_111010.pdf
Hope this is some help to you. Please let me know. Thanks & Happy Grilling!!
Jun 17, 2011 | Weber Genesis Silver B Grill
Crossover tube part no 9 how to we put it right in place. ?
The Cross Over Tube goes on the left side of the interior of the grill (as you are facing the control panel., attaching it just above the center burner. So that when the center burner ignites, it lights the Cross Over Tube.. To assist you more, I have included a link to the Owners Manual/Assembly Manual for your model grill. It does not go into a lot of details, but from the drawings and the Maintenance Guide, you can see where it goes.
http://www.weber.com/help/manuals/pdf_files/2009_grills/Genesis_310_320_LP_OwnersGuide_89478_092409.pdf
Hope this helps to get your grill back up and grilling. Please let me know. Thanks!
Apr 08, 2011 | Weber Genesis E-310 Gas Grill
Wont start just bought it it clicks but does not heat
Ensure that your hose, regulator, and control assembly are all clear of debris and that the orifice is not plugged.
May 29, 2010 | Weber Genesis E-310 Gas Grill
The electronic ignition on my grill no longer sparks to ignite the gas. I replaced the battery and cleaned the contact points but there was not any improvement. Can the entire assembly be replaced?
Yes you can replace the entire assembly.
However you can try adjusting the spark gap to see if this will resolve the issue.
Heat will often expand the spark gap thus rendering a spark impossible.
Small adjustments and be careful not to break the ceramic insulator.
Many gas grills use a static ignitor that does not require a battery.
Big red button you push that causes a snapping noise. This makes a spark and lights the gas. These can last quite a long time and inexpensive too.
Oct 03, 2009 | Weber Genesis Silver C Grill
  • Close the lid.
Jun 21, 2009 | Weber Genesis E-310 Gas Grill
Weber Genesis E-310 Gas Grill Logo
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
paulcarew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
