Question about Sewing Machines
Singer sewing machine 4530 c was working perfectly and sudenly stop. The pedal makes the machine sound like an engine that is trying to work (a buzzing soubd)
  • 323 Answers
SOURCE: SINGER LIMITED EDITION-MODEL 6268
More than likely you need a pneumatic transducer. It's the part that your air tube connects to and that is what actually makes your machine run.
sewman7
Posted on Oct 25, 2008
SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Posted on Nov 03, 2008
JeremySew
  • 65 Answers
SOURCE: foot pedal not working
You can purchase that singer sewing machine foot control here:
http://www.sewingpartsdirect.com/foot-control-w-cord-singer-979314-031.aspx
Posted on Apr 21, 2009
  • 980 Answers
SOURCE: singer 522 starts sewing at speed without the
Undo the foot control and take out the small square suppressor and throw it away, you don't need it anymore.
Posted on Dec 18, 2009
SOURCE: Singer Futura CE-250 Connection Error
My experience follows: If operating system is Windows Vista go to Singer Futura web site and down load a patch. Make sure you read and get the right one...This worked for me on one computer operating Vista...However, my laptop that is operating on Windows 7 and doesnt have the patch yet...from what I have read it is in the works waiting to be approved by Microsoft - Very Frustrating!
Posted on Jan 01, 2010
I need a manuel for a Singer Merritt 4530 sewing machine
Most Singer sewing machine manuals are available here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the Merritt 4530 is http://www.singerco.com/uploads/download/437_5_6_8_10_slide.pdf . Note: this manual applies to several machines with different available stitches.
I hope this helps.
Sep 01, 2017 | Singer Sewing Machines
How to oil the handwheel on a singer 4530 that has starting making a clicking sound in that area.
You buy some sewing machine oil from a sewing machine shop and then put a few drops on the shaft of the wheel as you turn it.
Jan 27, 2017 | Singer Sewing Machines
My singer will not stop running untill i pull the elec plug
it possible that either the foot pedal isn't working correctly
or the switch to the sewing machine is not work correctly
it needs to be serviced
Jan 17, 2012 | Singer Sewing Machines
Hi My foot pedal is stopped working sudenly
you can buy one at sewingpartsonline.com for about $35.
Sep 02, 2010 | Singer 8280 Mechanical Sewing Machine
My singer futura 600 will start for a moment then stops suddenly making a red flashing beeping sound. Is there a problem with the power pedal or what?
someone told me to take my pedal to an airconditioner repairman. i did. he cleaned and greased something in the pedal and now it works like a charm.
Apr 27, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer 2010 doesn't want to stop
I have a Singer Merritt 4530.  I don't know if the foot pedal works the same way on your model, but on mine it is held together not by screws or latches, but simply by white plastic rods that serve as hinges.  These rods have a hole drilled in their center, presumably so some special tool can be used to pull them out.  Lacking a special tool, I glued a nail into the hole, and once the glue dries you can pull the nail and pull the rod out with it.  The rod is about an inch long and held in place merely by friction - no glue or screw threads.  Once one rod is removed, you should be able to slide the pedal off of the rod on the other side, though that might have only worked because some of the plastic housing was cracked on mine.  If you don't want to take the time to test that, just glue a nail into both rods and pull them both out.
Once you get the pedal open, mine had a giant white cylinder that looks kind of like a battery or a fuse.  This thing was getting very hot the longer the pedal was left plugged in.  I read on many web sites that this object can cause overheating or short circuit the pedal so it's always sewing.  It's called a suppressor and can be safely thrown away.  I haven't found an explanation for precisely what it does or why it can be safely thrown away, but I theorize it's a surge suppressor and that most modern wiring isn't going to surge too much.  I got rid of it and the pedal still works and doesn't overheat.  It may be safest to plug the machine into a surge-protected power strip once the suppressor is gone - just my theory.
Feb 02, 2009 | Singer 132QRFB Mechanical Sewing Machine
Adjust timing on Singer Merritt 4530
what size replacement needles for a singer merritt 4530
Oct 21, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
16 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
