Question about HP DesignJet 9000 InkJet Printer
Media misaligned reload media
Al iniciar marca "check me lever load media" y al poner el material marca "media misaligned reload media" el carro de los cabezales no hace el recorrido apenas sale y se regresa y no se pone en linea la impresora realmente no me deja hacer nada Gracias por su ayuda
5 Suggested Answers
SOURCE: Error al instalar driver de scanner HP Deskjet F380
hi dear
i need ho deskjet f380 All in one
thanks
Posted on Sep 23, 2008
puertobori
  • 7733 Answers
SOURCE: En el display me muestra el error "Atasco
Trata este link en ingles pero facil de entender.
Posted on Oct 22, 2010
puertobori
  • 7733 Answers
SOURCE: buenas cordial saludo alas
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Dec 03, 2010
  • 628 Answers
SOURCE: Como puedo instalar la impresora
Obtain the software from www.hp.com/support.
Posted on Feb 26, 2011
Vue 2007 fusible de ventilador, al poner la cuarta velocidad de aire acondicionado se apaga.
Saturn vue 2007 el ventilador no se apaga se prende al momento de encender el carro y ya no se apaga
Jul 26, 2017 | 2007 Saturn VUE FWD 4
Hola le acabo de cambiar los empaque a mi 300 crysler y cuando ya avía terminado le quice echar agua y empezó a liquiar agua x un ojito que está junto al termostato
Se me hace que el empaque se movio cuando tratatse de hacer el reparo. Ponle un poquito de empaque liquido en un lado de el empaque, ponlo y deja unos minutos (como 10 minutos) y pon las partes juntas y apriete los tornillos; pero no muy apretados. Deja como 20 minutos y aprietalos bien; al torque aprobado para la parte. Ten cudado de poner el termostato al lado que se debe poner. Perdon de mi deletreado, tengo mucho de no escribir en mi idoma.
Nov 22, 2014 | 2006 Chrysler 300
Necesito programar un control a tv insignia?
Hola Maria, sera un placer asistirle con la inforamcion que necesita. Disculpe la tardanza en responderle. Quizas en este momento ya no necesite mi ayuda pero de todas manera se la proveere por si en un futuro la necesita. Para que su control funcione con tu TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Sigua este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV (Insignia). Una vez hagas esto te aparecesaran los codigos que posiblemente funcionan con tu TV. El procedimiento a programar su control es el siguiente: Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 720#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor o subir el volumen, deberia funcionar. Si funciona asegurese de poner el control en modo de satellite de Nuevo. Esto lo hace oprimiendo el boton de SAT en la parte de arriba de su control una vez solamente. Espero esto le ayude al no ser asi por favor envieme un correo electronico directamente a kimberly.escobar@dish.com
Kimberly Escobar Social Media Representative DISH L.L.C
Jan 16, 2013 | DISH Network IR Remote Control
Tengo un problema con el carro esta prendida la luz del motorsito esto que significa
Debemos asumir que esta refiriendose a la luz testigo del trablero que indica "Check Engine"...
Cuando esto ocurre, al computador del vehiculo le esta advirtiendo del mal funcionamiento o una se?al erronea que esta enviando algun sensor. Lo primero que hay que hacer es "escanear" la computadora con un Lector de Codigos, asi podremos conocer el "numero" exacto de este codigo, de acuerdo con esto, podremos iniciar tareas de diagnostico y reparacion.
Mantengase en contacto y envienos el codigo cuando lo haya determinado.
Sep 16, 2011 | 2006 Chevrolet Cobalt
Hola tengo un mando universal total control y necesito los codigos para el mini TDT mpg me puedes enviar los codigos o alguna url que me los ponga muchas gracias
MANDO ITC MODELO H-1080E LA TELE ES DE LA MARCA HANNSPREE Y ME HACE FALTA EL CODIGO,DONDE ME LO PUEDO DESCARGAR.GRACIAS
Jun 15, 2011 | Jensen Televison & Video
AL INICIAR LA INSTALACIÓN CON
Descarga los drivers desde la p?gina de HP support.hp.com, debes poner tu modelo de impresora
e ir a la parte de descarga de controladores.
Descarga los nuevos drivers y se deber?a solucionar tu problema.
Sino intenta con los drivers b?sicos.
Nov 05, 2010 | Office Equipment & Supplies
Haw can change the band of distrubution?
ok sure you speak spanish because we says to timing belt = banda de distribucion. I will write in spanish :)
Lo que tienes que hacer con la banda de distribucion de tu Jetta 1994 es quitar las bandas externas de tu auto, luego de esto lo que tienes que hacer es quitar la polea del cigueñal para lo cual iras a requerir un extractor de poleas, ya que extraigas la polea del cigueñal y quites la tolva que guarda a la banda de distribucion y a los de los arboles de levas entonces gira con el maneral el cigueñal hasta las marcas del tiempo q deben estar marcadas en el motor o monoblock y/o en las tolvas, verifica estas marcas poniendo tu auto en punto muerto superior que es que el piston 1 quede hasta arriba lo puedes ver con un desarmador claro para esto tienes que quitar la bujia de tu auto del piston 1.
bueno ya que tengas esto prosigues a marcar la banda con alguna tinta o corrector tambien marca las poleas de los arboles o arbol y la del cigueñal, quita el tensor y va a salir la banda.
cuenta los dientes entre marca y marca y luego de eso marcalos en la nueva banda de distribucion. con el tensor de banda contraido pones la banda verifica que esten en sus marcas y luego vuelve a tensar la banda con su tensor.
si no sabes cuanto tensar solo verificar que la banda no debe doblar mas de 60 grados maximo 90 grados si gira mas entones esta floja.
ya puesta la banda verifica y dale 2 vueltas al cigueñal con el maneral y dado, si quedan en el mismo lugar las marcas luego de 2 vueltas completas de la polea entonces esta a tiempo si se atora se pone demaciado duro entonces las valvulas estan pegando.
vuelve a poner todo lo que desarmaste y listo!
Oct 16, 2009 | 1994 Volkswagen Jetta
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
HP DesignJet 9000 InkJet Printer Logo
24 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
