Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Where is the pilot light on Raypak versa pool heater, i need to light it manually?
  • delvin175 May 19, 2009
    I found it, the pilot light is under the heater, over the burners, and on the right hand side. the shape looks like a stack of 5 nickels.
    Hope that helps somebody else.
  • 4 Answers
In side the front on the lower right is a long 3/8" wide tube about 5 inches long...you'll need a special lighter with an extended wick.
Posted on Aug 07, 2009
  • tinahannas Aug 07, 2009
    Inside the front panel on the bottom right: it's about 3/8" by 6 inch long tube.
4 Suggested Answers
  • 139 Answers
SOURCE: I HAVE A RAYPAK VERSA, PILOT IS ON , BURNERS DONT COME ON
check mv output of thermopile ,unless you have 350-500mv it is not enoughvoltage to power valve
Posted on Jun 20, 2009
johnsonr1
  • 91 Answers
SOURCE: pool heater wont fire up
Its just after 1 am here as well, Ontario Canada. Yes, you have to remove the front lower panel by raising it then pulling out at the bottom. Then compare the valve you have with the 2 in the picture on pg 5. If it is easier, you can have your husband call me while doing this and I can talk him through it. My contact information is located on the main page of my company website www.emshvac.com
Thanks
Richard
Posted on Jun 23, 2009
  • 990 Answers
SOURCE: Can't light my Raypak Pool Heater.
Often you can see the pilot if you use a small mirror. With the button on the gas valve pushed down you should get pilot. Once the pilot is lit it warms the TC(thermocouple) creating the static charge to open the gas valve on it's own. The TC is set in the pilot assembly. It will be a small tube like piece with the wires coming from it. Some times you can pull and replace it but I will usually get the whole pilot assembly and just replace that. It will probally be rusted and can be cloging the tiny orface on the pilot itself.
If you have a milivolt meter you can check the TC by pulling the wires that come from it at the gas valve and with the button on the gas valve pushed in and a good flame you should get 500-700 MV from the TC. This is 1/2 a volt+ so you will need a MV meter. But this will tell if your TC is bad or if your valve is bad.
Good luck.
Posted on May 13, 2010
Versa 130 Model Heater pilot light goes out when I jump the pp wires
put wires back and change pilot generator and thermocoupler
Jun 15, 2014 | Raypak Pool & Spa
Raypak pool heater pilot light problems
Could be several things. The heater should still be under warrantee. Have RayPak send a tech over, any DIY will void the warrantee.
Aug 02, 2013 | Pool & Spa
How can I convert a Raypak B55MP 55K BTU spa heater from propane to natural gas?
You would need to change the gas valve and the orifice in the pilot assembly.
Jul 19, 2011 | Raypak Versa 55k Btu Natural Gas Millivolt...
Versa 130,000 will not ignite spark works but will not ignite
You might have debris in the pilot orifice which is just below the pilot spark/light. Also might be a gas valve issue. Is the gas valve set to on? I would clean the pilot orifice first. Good luck.
Jun 19, 2010 | Raypak Versa 130,000 Btu Above Ground...
I have a natural gas poolheater- Raypak Versa 305. The pilot lights but when I release the button after waiting1 min. the flame goes out. This happens over and over so what should be done?
You, or someone should check the flame sensor. If , as it looks, you have a standing pilot (one that stays on), the flame sensor has to be aware of the pilot or all will go out. Good luck...Lee
Jun 10, 2010 | Raypak BURNER TRAY ASSEMBLY
I have a versa gas heater for my above ground swimming pool. This year the pilot will not light. It gets hot but will not ignite. Any ideas what could be wrong?
I have often found spiders or other **** nesting in the pilot tubes of these boilers which blocks the flow of gas. You will either need to have it professionally serviced or you can attempt to do it yourself, which I do not recommend.
Jul 11, 2009 | Raypak Versa 130,000 Btu Above Ground...
Pilot lights but burner will not fire
what burner where on the oven or the cooktop, if its the oven it may need new gas valve w\ thermocoupler
Jul 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
3,376 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
