Question about GE Dishwashers
Water standing at end of cycle
When the cycle is done, a couple of inches of water is still on the bottom
  • 12 Answers
You probably have a clogged return line to the sink/drain.
If water gushes out from under the overflow cover (next to sink faucet) with the screw cap in place then you have a plug between the overflow and the garbage disposal or drain.
If water isn't gushing from under the cover remove the cover and the screw cap. Look for something plugging the small diameter tube. (Note: If you run the DW with the screw cap off you could have a small gyser.)
If there are no visible plugs in the end of the tube then:
Remove the front cover from under the dishwasher and locate the drain hose. Remove the hose connection from the diswasher (black hose connects to DW discharge hose or housing). Try to blow through the hose, air should easily escape. If it doesn't you have a plug somewhere in the line to the drain.
If the hose is short you can try to clear the clog with a coat hanger, the easiest fix though is to just replace the hose.
1. Find replacement hose
2. cut the hose with a razorblade to leave a 3/8" strip about 4" long.
3. do the same for the replacement hose.
4. using wire sew the two strips together by punching holes in them.
5. wrap the splice in tape and some of the cut hose to make the splice the same size as the original hose.
6. Push the hose under the DW and pull from the drain side to get the new hose in place.
7. Cut-off the splice and attach the new hose to the overflow.
PS> Most of the time the clog in the hose is caked DW detergent and is hard to remove without pulling the hose out.
Hope this helps,
Kal
Posted on May 18, 2009
Standing water in dishwasher
This is because you have a problem with the diswasher pump and/or pump motor. There should NO water standing at end of cycle.
Sep 20, 2009 | Tappan Dishwashers
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Standing water at end of cycle
It is normal for a small amount of water to remain after each loadof dishes is cleaned.
Is the water clear or cloudy?
Is there an odor?
How deep is the water? Less the two inches?
Post back with your findings here. OK?
Apr 16, 2009 | Dishwashers
Water standing at the end of the cycle in my Bosch dish washer
where is the water is it visible above the filter plate or is it in the bottom of the sump
if its in the bottom of the sump thats normal it will always leave water in the sump
Mar 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. I can manually hit the start button twice and it will go...
Hi jeffwirch,
I'm Harvey the Master Plumber.
Your problem is: You have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. You can manually hit the start button twice and it will go through a 2 minute cycle and pump out the water. You have cleaned the filter inside the dishwasher where it drains and have checked the hose to the disposal and it pumps out fine. It just doen't pump itself at the end of the cycle.
It sounds like a bad control board. It's in the top of the door panel. I don't recomend this repair to the average homeowner. You might consider the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Maytag Dishwashers
Dishwashers Logo
195 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
