Question about RTO Atwood Water Heater - 6 Gal LP
Intermitent heat from Atwood 10 gal marine water heater
Our 2008 10 galllon Atwood marine hotwater delivers hot water when our freshwater tank is full and then stops delivering hot water when the freshwater tank is half full? No breakers are tripped. Full flow of water from hotwater tap at all times but it runs cold when the supply tank reaches about half full?
  • steve939 May 24, 2009
    turns out the high temperature thermostat was defective so I replaced both thermostats and viola hot water
    President:
  • 3,433 Answers
Water level safety shutting down heat source
Posted on May 24, 2009
  • Ned C Cook
    Ned C Cook May 24, 2009
    Thank you for sharing your results. It helps add to the helping of others. So, the water level was totally unrelated? I'm glad your up and running.
Tank full of hot water,faucets deliver only cold,water trickels into tank with rapid intermittend pump action
1) Copy following link:
http://waterheatertimer.org/Crossover.html
2) Add comment with clear description of water heater, fuel type, and pump?
Is this a pump problem or water heater problem?
Is this a water well pump?
Are you getting good stream of cold water at tap?
Which water heater do you have?
Is the heater new?
Or older heater that stopped working.
Dec 27, 2012 | Atwood 10 Gallon Gas/Electric Water Heater...
Atwood Hot Water heater wont' shut off
sounds like defective thermostat/gas valve
Aug 05, 2012 | RTO Atwood Water Heater - 6 Gal LP
Have an atwood 10 gal water heater that leaks but I can't find the leak. The lines are dry. Have a lot of water in interior under the bathroom tile.
Also open cover and check if element is leaking. Elements frequently leak at rubber seal.
Next suspect is rusted-out tank that is leaking through a thin-place in the tank.
Otherwise there are not many other places to check if pipes are dry, especially with the Atwood 10 gallon.
I suggest replacement.
http://waterheatertimer.org/Water-heater-is-leaking.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | RTO Atwood Water Heater - 6 Gal LP
My Atwood 6 gal. water heaters pressure relief valve starts dripping shortly after (8 or 10 min.) heat is called for, and dripping gets stronger until a full flow. I have checked all four hi-limits and...
If the water seems hotter than normal, then a faulty thermostat would be a good bet.
If water doesn't seem any hotter than normal, then check incoming water pressure.
usually 2 things cause that, too much pressure coming in, or thermostat faulty and not cutting out when normal temperature reached, thus higher temperature, and pressure. If both them check out, replace valve.
Oct 30, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Have a 2005 coach w/Atwood DSI-RV 6 gal water heater. Gas lights, heater fires and gets hot, but doesn't transfer the hot water through the lines to the sink faucets. jwmystery@aol.com
You need to check by-pass valve(s) on back of tank for proper position. You need cold open going in to bottom tank fitting, and hot open at top. If any valves in between those 2 lines via "T"'s, turn them to off position.
Oct 29, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have hotwater in the tank but none at the faucets.
By-pass may be faulty. Are you getting good pressure on hot side, even though not hot?
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
Water heater working fine but very little hot water coming out
alot of time those small units do not have a fast recovery rate so if they are on for a min or more they might start to lose temperature. if it's on demand especially in cooler climates it might not have enough power to heat it up and keep up with your demand
Jul 29, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwood 6 gallon water heater gets warm not hot. LP
You have a cracked dip tube. Part at hd is under 10 dollars. Remove and replace via cold water inlet side top of water heater. Degree of labor skill 1-10 = 8.
Please Rate.
Apr 04, 2009 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood Water Heater - 6 Gal LP Logo
282 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Donni Steen
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
