Question about Panasonic DVD-S35 DVD Player
Surround sound echo
When i use my surrround sound through the dvd player its fine, but when i connect it to my telvision it delays and i end up getting an echo any ideas why this is caused and how i can fix it. thanks tom
4 Suggested Answers
SOURCE: surround sound
You need a cable from your audio outlet to the home theatre receiver. Veira link is just for the picture. Only one way transmission. Optical cable or the 2 wires. Both options are available.
Posted on Dec 17, 2007
  • 47 Answers
SOURCE: How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Posted on Mar 09, 2008
alexander404
  • 276 Answers
SOURCE: Can I connect a Sony DVD Player DVP-SR90 to the
You can connect your Sony DVD player to your Panasonic HT using an analog RCA audio cable (white and red) for stereo sound. Connect to the AUX inputs on the HT and select AUX. Since the Sony DVD player only has SCART, you would need an adapter, scart to RCA. Like this one:
http://www.maplin.co.uk/scart-to-3-phono-plugs-with-in-out-switch-28102
Check for compatibility. Use the red and black RCA plugs for the audio into the HT.
Your Panasonic HT does not have a digital audio input which would be required for multi-channel surround sound (Dolby Digital 5.1)
Posted on Mar 14, 2011
When i connected the 5.1 home theatre to the LCD tv, there is a lag between the sound from tv and stereo system (just like echo).
That is very common because of video processing delay. You have to listen with either TV speakers or surround sound; but not both. Some TVs have an audion delay adjustment for TV speaker sync.
Apr 19, 2010 | Televison & Video
How do i put the surrround sound on my tv?
Depends on the complexity of your home theater system, but if you are just wanting to get sound from your tv to a generic souround sound, this is very simple. On the back of your tv, there is a audio output with 2 rca connectors. One is white and one is red. Also on the back of the sound system is the same colored inputs. Get the needed cable to connect the 2. You should have surround sound. Given you tv doesnt have audio outputs, your media player ( dvd, vcr, blue ray, sattelite) should have an audio output. Connect the electronic the same way as stated above.
Sep 10, 2009 | Durabrand 5.1 Surround Sound Computer...
System echos when dvd is in. When I mute the Bose sytem I can hear the TV sound without the echo.
The echo you hear is the audio delay between your TV speakers and Bose speakers. Muting (or lowering the volume) on the TV will eliminate the echo. Some TVs have a setting to turn of TV speakers entirely, allowing you to listen to your TVs audio strictly through your Bose system.
Dec 20, 2008 | Bose 3·2·1 II System
Speaker is not detected
If you are connecting a 5.1 surrround sound rather than 7.1, have you connected the surround speakers to the surround left and surround right rather than surround back left and surround back right?
Nov 11, 2008 | Onkyo TX-SR703 Receiver
Sound echos
Turn the sound down or off on the TV remote and only use the surround sound....
Mar 03, 2008 | LG DR787T DVD Recorder
No sound from TV only when playing DVD
Check carefully the RCA conections or others.Sometimes this conections break inwards end cause this problems.Check also the lead and the Set up from surround sound.Verify if the TV has settings for this kind of operation. A strong hug !!!
Jan 16, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
DVD sound problem
Go into the setup menu into the audio options (use arrows on remote to go up and down menu and press left to enter the next menu to change options). By memory when I was running this just through a TV and not through a surround sound system, I had to turn off the addition speaker options in the audio menu. The one's like centre speaker etc have an small/large/off option. I had to turn these off so that all sound would come through the TV speaker only. That is about all I remember as I was trying to get this running for my aunt and I no longer have the DVD player.
Oct 04, 2007 | GoVideo DVD-VCR Combo
Echo when playing surround sound
You want to adjust the "DELAY" setting on the receiver. The standard (default) delay setting is 20mS, which may need to be shortened if your speakers are well behind your listening position. In a proper setup, you should not detect a significant echo effect in surround programming (unless it is a purposely "echoey" scene). Also, make sure you don't have any of the "enhanced" DSP modes engaged -- some of these are quite echoey. if it has speaker set up, there should be a setting for distance. You might have it set close, so that by the time you hear the fronts, the rears should go. Try setting it farther each time until it sounds right. good luck
Mar 24, 2006 | Teac AG-D8900 Receiver
Panasonic DVD-S35 DVD Player Logo
179 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
