Question about Neff H5642 Convection / Microwave Oven
NEFF H5642 MICROWAVE STOPS WORKING AFTER FEW SECONDS
  • 32 Answers
Inverter board fault -part 482202,expensive repair
Posted on Sep 06, 2009
SOURCE: Neff Microwave
check control circuit and full wiring and connectors.
Posted on Dec 01, 2007
SOURCE: Neff HTHB86K Microwave oven.
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
Posted on Feb 15, 2008
  • 9 Answers
SOURCE: Neff H5642 1000 Watt Microwave
Sounds like the Magnetron may have collapsed. Probably not worth repairing. Check for burnt/browned components on circuit board/s. Burnt wires, insect or ant damage or soiling. Magnetron is the large-ish square metal object with lots of heat-sink fins on it. Check for discolouration. If nothing obvious, it's probably stuffed, If something is obvious, it's still stuffed, but it may be repairable.:::Spiceweasel.au
Posted on Apr 04, 2008
SOURCE: Neff 5474.0/gb. When microwave time
After a bit of digging, it appears to be an issue with the door not being closed correctly (or at least the it thinks is isn't.
Ref:http://www.sampfordixl.com.au/gaggenau/upload/BM221130_instr.pdf
I know its a different model but the functionality is identical...
Posted on Jun 12, 2008
SOURCE: microwave starts as normal but cuts out after
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
Posted on Mar 24, 2010
Testimonial: "Excellent. Thanks so much for your very quick and valued help! Will do as you suggest and give further feed back on outcome. Again, Many Thanks. "
Hi i have a neff microwave h5642nogb/02 when i switch it on to heat up food it cuts out after about 10 seconds can you please help
The magnetron is probably not working and the main board senses that.
Call an authorised repairer to fix it for you. There are no user serviceable parts in that section of the machine.
Feb 18, 2011 | Neff H5642 Convection / Microwave Oven
Oven accidentally operated without any contents and cut out with a smell of burning. Subsequently the oven only runs for approximately 22 seconds before stopping. Any ideas?
It will require a new magnetron and possibly power supply for it. The magnetron will destroy itself if it has nowhere for the energy to go.
Feb 14, 2011 | Neff H5642 Convection / Microwave Oven
Neff h5642 doesn't start at all. No lights, no display. What should I check first?
safety fuse (internal) will have blown usually caused by faulty inverter short circuit if fuse changed and blows again this is what it will be costly repair if out of guarantee.
Apr 19, 2010 | Neff H5642 Convection / Microwave Oven
Microwave starts as normanl but cuts out after 5 seconds on all settings?
sounds as either inverter or magnetron is faulty difficult to diagnose although when mag fault usually runs for about 22 secs inverter fails sooner around 5 secs.
Apr 09, 2010 | Neff H5642 Convection / Microwave Oven
Microwave starts as normal but cuts out after
Mar 24, 2010 | Neff H5642 Convection / Microwave Oven
Turntable Doesn't Rotate in Neff H5642 (1000w)
I'm sure your motor has failed.
Sometimes it a broken post inside the motor, if you like to tinker.
Otherwise I would contact Neff's service people for a spare.
Aug 22, 2008 | Neff H5642 Convection / Microwave Oven
Apr 04, 2008 | Neff H5642 Convection / Microwave Oven
Neff H5642
Your question is unclear, but you should probably have more door overlap on the front face than 4mm top and bottom. This will be ok if the door fits into a flush frame when closed.:::Spiceweasel.au
Mar 26, 2008 | Neff H5642 Convection / Microwave Oven
Neff H5642 Convection / Microwave Oven Logo
755 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
