Question about Thermaltake A2396 USB 2.0, eSATA External Drive Case
Need a driver for Thermaltake A2396 USB 2.0, eSATA External Drive Case
My computer doesn't recognize my Thermaltake A2396 USB 2.0, eSATA External Drive Case. I think I need a driver for it.
2 Suggested Answers
MooseMe
  • 30 Answers
SOURCE: Drive case flashes
The first thing you need to do is figure out if it is the Hard Drive itself or the enclosure.
The best way to do that is remove it from the enclosure & test it either in a PC directly or in another enclosure. If it works, then you can test the enclosure by inserting another Hard Drive & testing it. This should tell you which component is bad.
Posted on May 14, 2009
I need the instructions for Thermaltake BlacX ST0005U
The manufacturer page for this item is here: http://www.thermaltakeusa.com/products-model.aspx?id=C_00002058
Their support page does not provide a manual, instructions or drivers.
I suspect that is because none are needed. This is essentially an external hard drive enclosure for SATA drives which are standard. Connected via eSATA or USB.
Oct 21, 2014 | Thermaltake Computers & Internet
My windows 7 Home will not read my new Thermaltake BlacX Duet. Downloaded new driver and still no luck. Anyone have some suggestions? Im not a programmer, but can follow instructions. Thermaltake web
try with knowingly functionating hdd, also hdd sometimes will not display in my computer due to partition error, but will display in control panel- administrative tools - computer management - disk management , new hdd-s might do the same because they only have unallocated space,and need formating. I don't know if the device itself should display itself or not, check in device manager but maybe its normal that its invisible and shows only hdd-s. If a hard disk has malfunctioned to an extent, you will not see it anywhere in windows
hope this helps
Sep 17, 2014 | Thermaltake Blacx Duet St0014u 2xhd Sata...
Windows7 sabrent drivers
hello,
your hard drive should be recognized by win automatically when you plug in.
Aug 29, 2012 | Sabrent EC-UEIS7 USB, eSATA Internal Drive...
Computer doesn't find back up drive
try to an another pc, if your backup works, then you need to uninstall some drivers from your pc
Mar 03, 2010 | S3 iMicro IMB5EE-B 3.5inch eSATA & USB 2.0...
1tb Drive flashes, but will not be recognized by computer. Tried on both XP and Vista machines. Not seen by either. Is there any way to remove drive and place inside Vista box?
yes if your system has supports sata drives.
just take out of the case and install in your system.
make sure you have a sata cable.
Have you tried esata there is a cable that plugs into the mother board and goes into a pci blank slot that gives you esata this is the easest way to go
Jan 10, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Do external HDDs with both eSATA and USB require both to power up?
No, one or the other.
I wondered too, when my new eSATA external disk did not work with my laptop.
If you have a faulty eSata connector into your laptop the eSata won't work at all, but you can probably still use the USB until you can get a better quality eSATA expresscard / PCI connector. I think the standards have changed and an older eSATA expresscard won't do the job with modern laptop and disk.
Aug 04, 2009 | Acomdata Samba USB Enclosure Kit Red IDE...
Computer does not recongnize connection
External is damanged or you have problem with USB drivers...
May 10, 2009 | Beyond Micro MobileDisk 500GB 3.5 External...
I have had to reinstall my operating system and drives but now the Seagate 500 GB external is not recognized. What now?
Are you using eSATA for the External or USB. If it is eSATA you may need to get the respective drivers for your motherboard for it.
Jan 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Thermaltake A2396 USB 2.0, eSATA External Drive Case Logo
73 people viewed this question
Top Thermaltake Computers & Internet Experts
Martin Clarke
Martin Clarke
Lawrence Oravetz
Are you a Thermaltake Computer and Internet Expert? Answer questions, earn points and help others
