Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice maker stopped working
I have a Kenmore Cold Spot side by side refridgerator. 4 yrs old. My ice maker stopped working. I do get water.
  • Kenmore Master
  • 19,396 Answers
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
My kenmore side by side is not producing ice and there is a red light blinking inside the freezer sec
Can you locate your model number inside the fresh food section around door frame? I believe you have the ice maker with the electronic eye and sounds like you need to follow these instructions so the ice maker works again. If I am wrong then please correct me by posting your model number that should look like this example=> 321.234567 Click Here=> Whirlpool Ice Maker Infrared Electronic Eye Technical Information I am here if you need to ask questions, Sea Breeze
Nov 30, 2013 | Kenmore Side by Side Refrigerator
GE Profile Refrig model PSC23SGRC ice maker stopped making ice. Water is ok, just stopped? Is this common? Its only 4 yrs old
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
Jan 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Cold spot not making ice
you may need to plaug in the solonoid
look for a tan and whit connector
and the paddles on the soloinoid
right behind the panal where you connected the watewr
Oct 08, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore hotspot ice gets stuck same spot
if the cubes are small the water valve may be bad. Also pop the cover off and see if there is a plastic tab laying loose in the cover . It should have 2 holding the center plastic gear on if only one is in the center the ice maker is bad. Also make sure to change your filter ever 6 to 8 months if you have one this will stop other problems.
Sep 23, 2009 | Freezers
Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
Jul 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker not working, light blinking
I contacted Sears repair service and had the Ice maker and control panel replaced.
Jan 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
313 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
