Question about Kenmore Refrigerators
I have a kenmore compact model 461.95882. the temperture buttons do not work. I can't adjust the temp.
Nothing happens when you try to adjust the temperature.
  • 12 Answers
SOURCE: temperature control
For the Kenmore, keep pushing the button and it should cycle back to the top of the temperature range.
Posted on Oct 05, 2008
bobicehouse
  • 1524 Answers
SOURCE: my kenmore elite model 77719 french door
Check your ADC :http://www.applianceaid.com/adaptive_defrost.html
Posted on Apr 20, 2009
  • 52 Answers
SOURCE: Temperature at below zero; temperture control not working
Sound's like your cold control is bad.
Posted on Jul 14, 2009
iwillfixforu
  • 619 Answers
SOURCE: i have a magic chef compact refrigerator model
Sounds like defrost timer on back right corner has stopped in the defrost position. Located bottom left corner inside white plastic box if you are behind ref.
Posted on Feb 01, 2010
SOURCE: bottom freezer has high temperature and is
my freezer has the hight temp light on in red, and the frigde seems to be freezing and the freezer is defosting
Posted on Aug 12, 2011
How to fix kenmore f 3 code?
f3 code is the code for the oven temperture sensor that control the oven temperture need be replace ok
Dec 13, 2017 | Washing Machines
I can't turn my Kenmore upright freezer on.
Try disconnecting power for about 30 seconds, and then restore power. This will reboot the control and maybe restart.
Jul 09, 2017 | Kenmore Freezers
Kenmore 1.8 cu. ft. Compact Refrigerator stopped running and won't turn back on?
It is really hard to say why it shut down, but my best advice is to make a service appt. asap to have the problem looked at.
Feb 15, 2012 | Kenmore Refrigerators
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
Won't come up to temperture
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 30, 2010 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Nov 18, 2007 | Dacor Epicure ERD36 Dual Fuel (Electric...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
