Sony STRD-G510 Keeps going into protect mode. Is the unit broken or is there something I can do about it?
    Genius:
  • 1,847 Answers
Is it overheating, check the air curculation around the unit. Is it full of dust causing it to overheat?
Also let me know you get the problem when increasing the volume?
Try disconnecting all the speaker and connect on by one.
Let me know the status
Thanks
Kevin
Posted on May 18, 2009
How to run receiver+mixer+pre-equalizer-mixer+equalizer+receiver in loop
solution 1
repost this to right forum for other experts to solve
Jun 02, 2012 | Sony PC Notebook
Sony home theater system
Hello
There is some short inside the internal circuit board. Normally, this short will occur to its audio output section. If any audio output IC get shorted, the set will switch to protect mode. If this mode should chage to normal, you have to find out the damaged component, and should replace them with same type and number. OK.
Dec 23, 2011 | Sony Audio Players & Recorders
Shuts down in protect mode
disconnect all the speakers and turn it on. if it does not go into protect mode, then youve got a bad speaker or wire. good luck
Feb 10, 2010 | Sony STR-DE597 Receiver
My SONY HT-CT 100 Keeps going into "Protector" mode - even though there's plenty of airspace and the room that it's in is at 65 degrees farenheit
Protector mode does not just react to ambient temp. Try unplugging all the speakers from the back of the unit and turning it on. If it continues to go into protect mode, it is most likely a bad power supply or possibly a bad D/A circuit. If it does not go into protection mode when the speakers are disconnected, try hooking up one speaker at a time (while the unit is off) If the unit faults again when you turn it back on, it should point toward a bad speaker or crossed wires.
Dec 28, 2009 | Sony HT-CT100 Theater System
Sony tva-ve170 keeps going into protect why???
Fan is broken so overheats. Same is happening with mine just need to fix fan I believe. I used it with a a office fan on top and it worked a lot longer.
Aug 09, 2009 | Sony Audio Players & Recorders
Sony mhc-dx5 power protect
something inside the unit has become faulty electronically, otherwise if u have moved the unit with cds inside, they may be out of allignment and causing the unit to go into protect.
Jul 06, 2009 | Sony Audio Players & Recorders
Stand by light just keeps on flashing red and i cant press any otehr buttons it just keeps flashing red
something inside the unit has caused it to go on protect mode it sounds. check the v supply from the fan as well as the audio output ic and main pc board.
Jul 05, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Protector flashing
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Oct 05, 2007 | Sony STR-GA7ES
Amp keeps turning itself down - cant turn off 'protection'
yes,pls.stop plugging the system,you may harm your system if you do so,the system has it's own system analysis mode,and if there's something wrong in the circuitry,it will activate,you need the authorize service center my friend,it's a technical problem.
Dec 09, 2006 | Cambridge Audio Azur 540A Amplifier
My receiver is in protect mode.
The units in the protect mode because the Microprocessor detects a large current being drawn by the amp. section of the reciver. This is a solid state unit and there are no user replaceable parts inside this unit. Unless you know how to trouble shoot sloid state devices then you should seek a pro to assist you with this repair. GOOD LUCK
Jun 25, 2006 | Sony STR-DE597 Receiver
 Grubhead
Grubhead
