Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
How do i remove head from ryobi 3043ye line trimmer
SOURCE: Ryobi 105r replacement line
Look at the top of the spool. Line up the two triangles/arrows by turning the inner wheel The inner wheel is a little smaller that the diameter of the spool and has grip lines scored around it. Just below those arrows, on the side of the spool there is a hole where the line would come out of. Thread the line into that hole until it comes out through a hole on the top of the spool. Then bend the end of that line over and stick it in the little hole next to the hole it came through. That will lock it in place. Pull on the other end of the line to tighten it. Now turn that inner wheel and the line will wrap around on the inside of the spool. When it stops and you can't turn it anymore, it's full. Cut the line off about 10 inches or so outside of the spool.
Posted on May 19, 2008
SOURCE: Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Posted on Mar 17, 2009
SOURCE: Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Posted on May 18, 2009
#1 Taper
  • 1040 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
SOURCE: ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Posted on Sep 04, 2010
Oil leak at the back
do you have an automatic oiler, or do you need to premix your fuel? if it is an automatic oiler, and I assume it is since that is the only oil involved in any trimmer I have ever owned, then I would say you have lost your supply line for the two stroke mix, this can be easly solved in a couple of ways, empty out the reservoir, and start to premix your fuel 40:1 would be fine, or you can fined the oil line and reatach it,
Apr 08, 2014 | Garden
How can i strimmer wire on a ryobi plt 3043ye
Hi alice louise
Try this method
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 02, 2011 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Reeleasy line trimmer head PROBLEM
sounds like the clip isn't engaging properly. For a bump and feed they have steps that lock when enough cord is set out. If the head is not locked when its on it will recoil in. Try to make sure its not sitting wrong.
Apr 20, 2017 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I want to access the pull cord reel on a Ryobi trimmer PLT 3043YE
This appears to be a model only sold in the UK but it looks like the standard, Ryobi,Homelite,Toro, trimmers we have in the states. You have to remove the 4 screws that hold the motor to the shaft to access the recoil starter. Once apart it will become evident how to remove the starter parts. Hope this helps.
Sep 16, 2009 | Ryobi Garden
Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Jul 05, 2009 | Garden
Remove head to restring
you need to locate the black knob at the trimmer head and turn it coun ter clockwise and remove it to access your string spool you may have to chase the knob with pliers because some are more than hand tight
follow arrow on the spool for line winding direction
May 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Starter cord tangled on shaft 3043ye
to remove the clutch remove the four screws that connet the trimmer shaft to the engine, remove the shaft. Then insert the correct torex head driver into the center of the clutch cover. There is a screw (the same head as the screws that holds the trimmer shaft on) Remove the clutch cover, insert a screwdriver into the engine cooling fins to hold the engine from rotating and turn the clutch from the engine. The clutch had a remove arrow to help with the direction to turn in order to remove.
May 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi RLT30CES line trimmer head problem
Many small line trimmers lack a clutch system by design so this could be normal.
May 24, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Whipper Snipper plt 3043YE. change clutch plates
Waiting for some information, current had no reply.
Ryoby sent me a line diagram, would be gratefull for further information please.
Cheers
Justin
May 13, 2009 | Ryobi Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
44 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
