Question about Eureka 431A Optima Bagless Upright Vacuum
Eureka Optima vacuum has suction at the hose but not at the floor. I took out the filter and it still isn't suctioning so I don't think it is the filter.
  • 4 Answers
It sounds like you have a plug. check where the hose goes into the back of vac. it should have a clip remove this and see if there is a plug there
Posted on May 20, 2009
The same thing happened to mine- it turns out the belt was broken! So just replce the belt- it's about $4-$5. Your manual should explain how to do this.
Posted on May 30, 2009
2 Suggested Answers
pappapumpdaf
  • 635 Answers
SOURCE: My Eureka Optima vacuum doesn't have any suction
It will as long as long as your accessory hose is properly inserted into the base. Otherwise the vacuum stays on the hose only.
Posted on Mar 14, 2010
I have a Eureka upright bag less model 5857 az. The hose has suction but not for the carpet. Is there a switch that needs to be turned to floor suction? I do not have a manuel.
I'm just guessing here, but have you laid the vacuum down with the underside of its head showing? There is a channel that runs from the brush section to the hose when it's connected correctly to the head. Look for item(s) that may be jammed into that channel. Ensure that the hose is properly attached to the head. If you feel no suction on that underside channel, you have something jammed in it.
Oct 19, 2014 | Eureka Vacuums
Eureka Optima Lightweight suction weak on bare floor, hose only works when dial is turn to floor?
I think it is normal. My favorite setting is the dial is turned to bare floor. If you set your vacuum to hose, then you need to adjust the height (do not set the dial to the bare floor).
Feb 21, 2014 | Eureka Vacuums
I have a Eureka Contour model 2900 type A upright vacuum, the roller works fine nothing clogged, took it apart motor blade is free of debris, no suction from tube and blasts OUT air from the front HEPA...
Even with your explanation,it seems the hose is clogged.Try taking the hose off,then blow through it or pour water through it.If this doesn't do it,make sure the suction canals are going to the proper areas.
Apr 04, 2012 | Eureka 2900A / 2901A Contour Bagged...
My Eureka Optima vacuum doesn't have any suction when on the floor option. How can I fix this?
Mar 13, 2010 | Eureka 431A Optima Bagless Upright Vacuum
Very little suction? Someone give me an answer please.
You must have something obstructing the airflow. There is sometimes a small trap door under the vacuum where the brush is located. Open that door and see if there is something jammed in it. If you don't have the door, then there is an obstruction somewhere in the vacuum. You should also look in the hose.
Jim
Jun 10, 2009 | Eureka 431A Optima Bagless Upright Vacuum
No suction from base or hose attachment
I had the same problem with my Eureka vacuum cleaner. I don't have the problem with the beater bar, but I had the problem with the attachment hose not getting any suction. I found out that I was putting attachment on the wrong end of the hose. The end that you use in the front. Don't how I got that confused because it always worked before. Hope this helps with the hose part of the problem.
Glen
Mar 19, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
My eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Jun 06, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka optima
The filter probably needs a darn good clean. If it is clean, wipe the inside of the canister with a clean cloth to get rid of static.
Oct 13, 2007 | Eureka 431A Optima Bagless Upright Vacuum
Eureka 431A Optima Bagless Upright Vacuum Logo
531 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
