Question about Redcat Racing Volcano S30 1/10 Nitro Ready To Run
Cant get volcano s30 to keep running i got the truck running and ran the break in tank through it without driving it adjusted it so there was smoke and oil coming out the exhaust and the truck wasnt moving . Let it cool and went to fire it up for the first figure 8 run and I got it to fire 2 times over 45 minutes but it wont stay running replaced the glow plug it works . Dont know what else to try !
4 Suggested Answers
rpq2112
  • 6 Answers
SOURCE: we were breaking engine in, was running great
What does it do when attempting to crank
Posted on Mar 06, 2011
SOURCE: the volcano breakes do not
I just got my Volcano S30 Friday, breaks worked great for 1 run not full speed, second run low speed no breaks at all, adjusted the linkage as requested by red at racing breaks worked good for 1 run then same thing no breaks, manually checked the breaks by hand the pad stops like it should except the wheels keep turning and the drive shaft as well.
Posted on May 14, 2012
kevin_boyce7
  • 3 Answers
SOURCE: engine will not stay running
Change glow plug first. And adjust to factory settings. Also nitro motors depending on outside temp can vary..
Posted on Jul 01, 2012
My 1995 4m40 mitsubishi pajero has its turbo charge seized and emmiting black smoke,it is poweless but the deisel in the fuel tank turns black in colour and can stop whilst driving.I cleaned the tank and...
The engine is not designed to run without the turbo. Fuel pump recirculates fuel to the tank to control pressure while driving and engine is running so poorly fuel is being diluted. Fix the turbo.
Jan 18, 2015 | Mitsubishi Cars & Trucks
My car starts easy first time and runs for 5 minutes then die and wont start up.
May be a simple thing sounds like fuel , check that your fuel filler cap breathe hole is not blocked , try running the vehicle without cap on a short distance to see if removing cap Cures problem. If not I would suspect fuel pump is on the fritz or maybe in line fuel filter needs repalcing
Jun 28, 2014 | Redcat Racing Volcano S30 1/10 Nitro Ready...
My volcanos30 starts easy runs for mintue then dies.then i cant get it started for about 20 minutes
Sounds heat related check seals around engine and see if any perished, sounds like as the engine is getting hot it's losing compression due to expansion,
I have a 97 nissan sentra ive ran out of gas 3 times this month and the last time i ran out of gad i filled it and drove it for a while that day then it shut off and wont start no more
more like fuel pump damaged. gasoline keeps fuel pump cool and lubricated if fuel tank run empty fuel pump will over heat which will destroy it. never run out of gas.fuel filter will get plugged with debris from fuel tank when tank runs empty all sediment botton tank will break up stop up fuel filter.
Jul 28, 2013 | Cars & Trucks
Clean carburetor
idle jets in cab need a good clean out ,how or where they are in relation to the carb i have no idea without a good look
Jul 26, 2013 | Honda VT 750 Shadow Aero Motorcycles
The volcano breakes do not work 100% WHEN RUNNING FULL SPEED AND I PULL THE BREAK, THE Tires do not stop like the shockwave. i bought new pads, tweack the screws,,,, nothing...maybe it is normal ?
May 27, 2011 | Redcat Racing Volcano S30 1/10 Nitro Ready...
Buying a 1995 f25 diesel from a frien and he ran unleaded gas in it and now it blows alot of white smoke
blown head gasket an the white smoke is the truck burning off the antifreeze thats leaking into oil big job to repair 1500$at a cheaper shop...bad to run without fixing due to antifreeze thins oil and internal damage to engine will result....thanks for using fix ya.good luck friend never ran gas a diesel will not run on gas and will shut down almost imeditely if clean diesel is dirtied in any way...
Apr 02, 2011 | 1995 Ford F250
Got a traxxas 2.5 i think? Been around plains for years and can tune them fine but for some reason i cant get the truck tuned. Starts fine cold but when running hard smoke goes away and starts to bog....
Sounds like the high end needle might be too lean. Have you checked the engine temp while running. Traxxas engines usually like to run around 210-240 degrees.
Sep 25, 2010 | Traxxas Rc Revo Nitro Monster Truck
What is the volcano looking electronic message in the center of the tac on a 2001 a6 also why would the air bag light come off and on and what would the service light come on when you first start it Thanks
this is the indicator for the windshield washer fluid tank, It needs to be filled. If it cant keep fluid it may have a crack in the tank or the pump
Feb 23, 2010 | 2001 Audi A6
Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Mar 18, 2009 | Garden
Redcat Racing Volcano S30 1/10 Nitro Ready To Run Logo
Top Redcat Racing Toys Experts
ray gallant
Are you a Redcat Racing Toy Expert? Answer questions, earn points and help others
