Question about Sylvania-Appliances 12,000 BTU Air Conditioner - SYL12PE
Sleep button turns on - Sylvania-Appliances 12,000 BTU Air Conditioner - SYL12PE
How do I turn off timer on aiwa nsxd5
I would press the sleep button to see if this resets the timer. But don't forget to continue to press the sleep button till you turned off the sleep option.
Jul 12, 2016 | Aiwa Audio Players & Recorders
Sound effects icon on iPad won't go away
try this steps:
Restarting, resetting, or Force quitting the apps.
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPad. To turn iPad back on, press and hold the Sleep/Wake until the Apple logo appears.
Force quit an app: Press and hold the Sleep/Wake button on top of iPad for a few seconds until a red slider appears, then press and hold the Home button until the app quits.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
Reset iPad: Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
Jan 18, 2015 | Apple iPad Tablets & eReaders
Turn off timer on home theater system
You can turn on or turn off the home theater's sleep feature by pressing and holding the [-SLEEP] button then repeatedly pressing the [-SLEEP] button.
Jun 22, 2014 | Panasonic Sa-btt270 Receiver For...
I have a Grundig radio S350DL and I cannot switch off the sleep function and therefore the radio automatically switches off after 30 mins. or so . Can you advise? Les. Akers
The Power and Sleep Functions share the same button. If you press the Power/Sleep button repeatedly you see numbers displayed 90, 75 60, ... 01. These are the duration of the sleep functions. If you stop at 60 the radio will work for 60 minutes then turns itself off. This must be a battery saving feature so that a radio will not be on for ever. Suppose the radio has been on for a while (long or short) and you want to turn it off without waiting for the sleep timer. Just press the Power/Sleep button.
Aug 10, 2011 | Grundig S350DLB FM Radio
My IPhone has frozen and I can't even shut it down. Can you help me with this problem?
you can try the following steps
  1. Press and hold the Sleep/Wake button until the red slider appears. When you see the red slider appears, release the Sleep/Wake button.
  2. then press and hold the Home button for six seconds
if the screen is still unresponsive try to restart the iphone by following these steps
  1. To turn the unit off, press and hold the Sleep/Wake button until the red slider appears.
  2. Slide your finger across the slider to turn off iPhone.
  3. To turn the iphone on, press and hold the Sleep/Wake button until the Apple logo appears.
if restarting does not work, try resetting the iphone
1. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds or until you see the apple logo appears
if your screen becomes responsive, try to reset the settings by going to the settings of y ur iphone then general then reset and reset all. after this, restore the files on your iphone through itunes
Apr 20, 2011 | Apple Cell Phones
What is the function of the sleep button on the TruTech TCR1276 Clock Radio. The alarm clock already has a snooze button.
The sleep button sets the radio to play for a set length of time and then turn off. Thus you can fall asleep with the radio on and not have to remember to turn it off. It works when the clock's Auto/On/Off switch is set to Auto or Off. The default is 59 minutes before it turns off. You can adjust the time until it turns off by holding the sleep button and the hour (lengthen the sleep time) or minute (shorten the time until it goes to sleep) button. The longest duration is 1 hour and 59 minutes until shut off.
I hope this helps. You can find the manual for the clock radio at: http://www.curtisint.com/support/manuals.asp . Search for the TCR1276.
Jan 08, 2011 | TruTech TCR1276 Clock Radio
Screen stay in white colour
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 02, 2011 | Apple iPhone Smartphone
Sleep set to Never - but did and couldn't recover
Setting the power option is applicable for the laptop when its running on power supply and not on battery.Make the same as the power battery settings.
Jul 19, 2009 | Computers & Internet
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Sylvania-Appliances 12,000 BTU Air Conditioner - SYL12PE Logo
13 people viewed this question
Top Sylvania-Appliances Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Sylvania-Appliances Heating and Cooling Expert? Answer questions, earn points and help others
