Question about Stanley Black & Decker Stanley Bc1509 15 Amp Battery Charger Sta-bc1509
Charger does not show amps
The display has stopped showing amps or amount of charge. What is problem
Not holding charge, battery display shows charging for a minute, so getting connection, but unplug charger and it dies immediately
you may consider replacing the battery, unless you find & try a charger that could recondition/revive a rechargeable battery
Oct 11, 2015 | Computers & Internet
Our cordless hedge trimmer will start but keeps stopping after about I minute it won't cut bushes have tried to recharge. How long does it take and should a light show to indicate it is recharging. Th
Most chargers will show a green light when charged
That could take an hour
You have to or I do,charge all my items every 3 months
Not uncommon to have a failed battery in less than a year
Ideally four years & fair amount of use,but some do fail
Oct 29, 2014 | Bosch ASB Cordless Hedge Trimmer/Grass...
How do you hook up amp meter for battery charger
DO NOT CONNECT IT to both poles + - !!! the amp meter have very small internal Ressistance, it blows of :) Connect it like in the picture d640b1d6-15c8-40ff-9dc1-eac0eb3b2a1f.png
Apr 16, 2014 | Cars & Trucks
Hi my I phone is not charging while it is on and when switch off it start charging???
Hi -
It is not uncommon for some devices to be unable to accept a charge while in use - especially if not using the supplied charger. This is because the amount of power required to USE the device (your iPhone in this case) exceeds the amount of power provided by the charger.
If trying to make a call, you may be able to coax your iPhone to accept a charge if you shut down un-needed services such as wifi, GPS and BlueTooth radios along with turning the brightness of the display down, etc. This greatly reduces the power requirements of the phone; and if the charger is powerful enough, it will begin to slowly charge your phone. The charge rate will be significantly lower - requiring a longer time on the charger - whenever the phone is being used AND charged. Once the phone is no longer being used, the charge rate will immediately increase, since AC power no longer has to be divided between charging the battery and operating the phone lights, radio, etc. This shortens the amount of time needed to recharge, significantly.
Whenever possible, use the the supplied charger - or one with the SAME voltage, polarity, and voltage type (AC or DC). The amount of current or wattage should be the same or greater than the original. Most phones use USB connectors and are 5 Volts DC. USB standards call for between 1/2 and 1 Amp current. Since watts is equal to volts x amps, this example would represent a 2.5 (if 1/2 amp) to 5 (if 1 amp) watt charger. If you could find a higher wattage charger while still maintaining the DC voltage requirements, you would be able to use and charge the phone at the same time.
I hope this answers your charger question & good luck!
Sep 04, 2012 | Cell Phones
The display now shows a picture of a battery indicating the amount of charge,instead of the minutes of charge left,eg.(99)
This is quite normal. There is no need to worry about that. Plug in the charger again and the display will change to numeric value.
Also you can charge your shaver anytime as it uses Li-ion batteries so the batteries will not damage easily.
Hope this helps..
Feb 27, 2011 | Philips SmartTouch-XL HQ9190 CC Electric...
When I plug in my jet 3 ultra the ammeter reads 0. If I turn on the vsi controller the top led display( 3 red, 4 yellow, 3 green) are all lit. I see where that means high battery voltage. The lower led...
Its showing you the voltage out put for the charger if all power lights are lit and the chager is pluged in if batteries show only 2vlts then they are no good and the will not charge up thats why amp meter is on 0
Mar 03, 2010 | Jet 3 Ultra Power Chair
Soney ericssion k810i keypad 1,3,6 not working and no.3 press display shows shutdown and putting charger shows indicator but not charging the battery sir please help me
soney ericssion k800i keypad 1,3,6 not working and no.8 press display shows shutdown and putting charger shows indicator but not charging the battery sir please help me plz
faraz_khan718@yahoo.com
Apr 22, 2009 | Sony Ericsson K800i Cellular Phone
Motorola razor v3 display problem
If the charger is not an original motorola charger,, then you have a problem. make sure its original.
Oct 11, 2006 | Motorola Mobility RAZR V3
Stanley Black & Decker Stanley Bc1509 15 Amp Battery Charger Sta-bc1509 Logo
Top Stanley Black & Decker Car Audio & Video Experts
xxxxxx xxx
Are you a Stanley Black & Decker Car Audio and Video Expert? Answer questions, earn points and help others
