Home | Zanussi | FJS1225W Front Load Washer | THE WASH REACCHES DRA...
Zanussi FJS1225W Front Load Washer
Problem for Zanussi FJS1225W Front Load Washer
THE WASH REACCHES DRAIN AND SPIN STOPS THEN ENDS CYCLE
By garynovember on May 18, 2009
hello,my poblem is when i run a cycle it stops when it reaches drain and spin then ends with water left i the washing machine it does this every time help!!!!!!!!!!!!!!!!!!
Best Solution
posted on May 18, 2009
Very Helpful)
marrek
Rank: Guide
Rating: 88%, 6 votes
pump is blocked check your filter at the front some have a small drainage tube there to remove the water. failing that tilt back machine slighty open door and remove with a jug, remove filter uscrew and pull and check for foriegn objects i.e coins screws,whilst tilted back squeeze the two rubber tubes to the pump to make sure they are clear or unclip if need be MAKE SURE POWERS OFF lay some towels down sit machine back down slowly there will be excess water and with filter out run machine SPIN ONLY if it does you've solved your problem also check your waste and outlet pipe your waste could be pushed too far down the outlet pipe 6" is adequate enough.good luck
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Zanussi FJS1225W Front Load
Questions and Unsolved Problems for Zanussi FJS1225W Front Load
Do you recommend Zanussi FJS1225W Front Load Washer?
Answer
Answer
i keep getting error messgae e20 when using dryer part of zanussi jetsystem turbodry 1200. it just... (More)
Answer
1220S Machine. Started but would not spin. Will not restart now.
Answer
not spinning as fast as should and washing very wet at end
Answer
Zanussi Jetsystem 1200 - Hello, The fabric conditioner does not drain into the machine and remains... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zanussi FJS1225W Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14193
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
