Question about Honeywell International Heil Quaker Honeywell 1014460 Control Fan Timer
How to change rotation on a blower motor
Hi I have a heil heat pump we recently replaced the blower motor but its rotating clockwise and is suposed to rotate counter clockwise it didnt came with any diagrams i has a plug with 6 contacts thr motor model is K55XEBS-7192 i need to know how to reverse the rotation on this motor thanks
Ac compressor fan running backwards.
Fan motors have rotations, clockwise and counter clockwise, lead end and opposite lead end. If you are looking at the motor from the fan blade side and the wires are on the back (opposite) side of the motor then you are looking at opposite lead end. Then you need to determine the rotation of the blade. It will scoop the air, so turning the blade that direction will give you the rotation. They also sell motors that you can change rotation by changing certain wires they have added.
When you replace a motor you need to notice the rotation and order that rotation. which end of the motor you are looking at to determine it. Then order the same rotation when buying the new one.
May 30, 2014 | Goodman CKL24AR24 Air Conditioner
Wiring a AOSMITH S48A93A66 FAN MOTOR FOR 110
Motor wiring will appear on label on side of motor, for Lo 110V, and Hi 220V.
L1 is Line 1 is usually Hot wire
L2 is Line 2 is usually Neutral wire
Motor will show direction of rotation CW clockwise.
Compare diagram with old blower motor.
http://www.centuryelectricmotor.com/Applications/AdvanceCatalogSearch.aspx#Blower%20Units
Take photo of label and include link to photo so wiring diagram can be viewed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 08, 2012 | Pool & Spa
Can switching wires on a capacitor change the rotation on a 220v pump
no . if your motor is turning clockwise (facing motor) the motor is most likely shorted and junk
Mar 26, 2012 | Hayward Pool & Spa
Fi have a older furnace that operates like this. main burners will come on then the blower turns on and furnace continues to heat untill it shuts down on the high limit. there is no blockage on the cold...
Maybe there is a blockage in the air conditioning coil above the furnace? This happens when people have pets, or dont use filters. Single phase 120-240 volt motors won't run backwards if you reverse the wiring that's dc or three phase, you have to check the rotation of the wheel, the right rotation is usually marked on the blower case. Some motors will allow you to change the rotation but you have to check the wiring diagram. Also use new capacitors when they go bad the motor can run backward. God luck
Dec 20, 2011 | Honeywell L4064B2236 Fan/Limit Control...
I have an 18000BTU unit that has an LED that flashes 5 times and then stops,could you pls advize as to the error code of the LED flashes.
You haven't mentioned the brand name. As the error code changes brand to brand I give some solutions. Check with your unit.
e-5 Outdoor activation of compressor over heat protection-Clean condenser coil and check out door f.motor speed. If less replace capacitor.
e-5. Blower motor lock Rotate manually. If hard to rotate, replace bearings or motor. If easy to rotate, replace capacitor.
Please mention brand name and other full details to get solution quickly. Thanks.
Jan 10, 2011 | Carrier 36KCARMS Air Conditioner
Only a little heat is going to the cylinder
Zuraxus what you are seeing is normal for a time. Here is how this dryer works. With a wet towel in the dryer, the first 5 minutes is testing to see if the load is wet. If so then between 5 & 10 minutes the dryer will turn on the 800 watt heater section (only in clockwise rotation). If still wet enough from 10 minutes to 15 minutes it will turn on the 1900 watt heater (heating only in clockwise). If still wet enough 15 to dry will turn on the full 2700 watts in clockwise and 800 watts in counter clock wise. That is how the cycle works. However it is hard to tell with the rear cover removed as the blower pushes the air thru the heater. Careful that by running with the back panel off you don't trip the high temp manual reset protector. So yes this sounds normal. What is the issue that is causing you to think the dryer isn't working proper?
Apr 20, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Washing Machine Fuse Keeps Blowing Off !!
check for earth leakage and a water leak.is the heating element ok
Apr 03, 2008 | Washing Machines
Honeywell International Heil Quaker Honeywell 1014460 Control Fan Timer Logo
239 people viewed this question
Top Honeywell International Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Honeywell International Hardware and Accessory Expert? Answer questions, earn points and help others
