Question about Panasonic DVD-CP67 Multi-disc DVD Player
I'm not getting the disk to read and the error comes up as H07.
Normal 0 This solution is most likely being submitted way too late tohelp "dingo 1295", but perhaps it will help others who run into thesame problem.
Just this past week, in January of 2009, I ran into the very same problem witha Panasonic DVD-CP67 DVD Player. The player would no longer play disks anddisplayed the H07 error. Now, I can't answer the question about what exactlythe H07 code is suppose to mean, but I can offer one possible solution for theDVD Player's inability to play disks and the subsequent display of the H07error. What happened in my case is that a film of dirt had built up between theelectrical contacts that are suppose to form a closed circuit when the player'sdisc drawer is closed. The two metal plates that make contact rub againsteach other and the abrasion eventually both creates and traps dirt where theplates touch. Therefore the player could no longer tell that the disk drawerwas closed because the dirt blocked the fragile electrical circuit from beingclosed. Since the player could not tell the drawer was closed it would not spinup and play any inserted disks. I'd also like to note that before the playerquite playing disks and started displaying the H07 error I was watching a DVDand did see the picture quality degrade until the video finally cut out and thedisk stopped.
The Solution in this instance was to carefully remove the cover from theplayer, after removing seven screws found on the back and sides of the player's case,and to clean the metal contacts with a non-abrasive eraser. The pink eraser ona NO. 2 pencil works perfectly.
On the back of the disk drawer, on the right side is a silver metal plate andat the back of the player, mounted on the plastic frame work around the platterthat picks up any disk placed in the player, is a folded copper plate held down with ascrew. Simply unscrew the copper plate and clean it with the eraser were itnormally touches the silver plate on the drawer when the drawer is closed,being sure you do not get any eraser dust inside the DVD player. Although thecopper plate will most likely be the plate with the most dirt on it you canalso clean the silver plate without removing it. Once cleaned, you can reattachthe copper plate with its screw.
Testing... You must place the cover back on the player before it will playdisks. The cover must be fully seated, but does not necessarily have to bescrewed on. You may have noticed when cleaning it that the copper plate has anupward folded tab that presses against the player's metal cover when the coveris closed. Without the copper plate touching the player's metal case throughits cover the previously mentioned electrical circuit won't be closed and theplayer won't play disks. With the cover properly back on the player go aheadand try and play a disk. If it works then the problem is solved and you canfinish screwing the cover back on. If the player still doesn't work thensomething more serious may be wrong and I would suggest contacting a servicecenter.
I hope this helps.
Posted on Jan 11, 2009
Player "reads" the DVD and then the display says "H07" and ends.
The "H07" is an error code, this particular error code refers to the dvd spindle drive motor. Effectively the spindle motor that spins the DVD isn't turning correctly and on occassion this can be that the spindle & bearings need lubricating due to partial siezure. But really this should only be done by somebody with a bit of technical know-how to avoid further damage to the machine or indeed an electrical injury to the person under taking the task. I can only suggest that you contact a Panasonic repair shop and to see if it is cost effective to repair.
Hope this helped,
James
May 02, 2010 | Panasonic DVD-RV32 DVD Player
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Error code h07
HELLO
I have just recently posted a cure for this - but here we go again. Fault H07 is the fault code for the spindle/disc motor and to cure it do this!
With the lid of the player removed, locate the spindle and where the motor shaft goes into the motor itself, use a little light oil or WD40. Let it soak in a while and try it again - you should now find it works.
Why this works I just don't know - it just does! (:-)
Sep 09, 2009 | Panasonic DVD-RV32 DVD Player
Panasonic sa ht800v error code h07
Hi,H07 code is the error code when the spindle motor goes faulty
Aug 13, 2009 | Panasonic sa-ht800V Home Theater Audio...
H07 error msg
This normally means the spindle motor is faulty
Jul 12, 2009 | Panasonic DVD-RV32 DVD Player
H07 code appears on the read out
hi..the reason to this problem is the motor.It may
be either spindle motor problem or the motor is not
spinning up.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | Panasonic DVD-RV32 DVD Player
DVD error HO7?
Will read dic and play movie for about 10 mins and then stop and give me the error code H07. What is this and how do I get rid of it?
Feb 01, 2009 | Panasonic sa-ht800V Home Theater Audio...
DVD/VCR combo says no disk
I would venture a guess that you have a Panasonic DVD/VCR combo. If yes, then it is possible that the H07 error is indicative of a motor problem. The normal corrective procedure would be to replace the motor.
If indeed it is a Panasonic and the motor in question, there is a temporary workaround which is better explained here.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 09, 2008 | Televison & Video
H07 on panasonic
hey I just messed around with mine it was showing that code H07 like the others its kinds the same except it holds 4 more disc, I took the top off then I took the thing that holds cd still off!, there should be a brass thing I think thats for the ground, so I ended up putting some synthetic oil on the rails silver poles that the laser slides on, and where the disc sits on that black circle under it, you can see the motor it has a white thing on the motores pole so I just put a few drops on there then spinds it put some more on hoping it works its way DOWN INTO THE MOTOR thats the H07 not spining fast enough!! I put a disk in while everything was apart and its playing right now, the oil I desided to use was the stuff I use for my paintball gun lol! its really thin and slippory and im sure it will last for awhile!.... going to add more after 15 minutes of playing just to make sure its really lubed! hope this helps!!!!
Jan 10, 2008 | Panasonic DVD-CP67 Multi-disc DVD Player
Error Message H07
You can reset this fault by holding in the reverse, pause, and the on-off button, all at the same time. If it comes back then the spindle motor is the bad componet, and unless you know how to disasemble a mechanism for a changer I would let a pro handle it.
Jun 19, 2006 | Panasonic DVD-S35S DVD Player
Panasonic DVD-CP67 Multi-disc DVD Player Logo
173 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
