Question about Whirlpool GEW9250 Electric Dryer
Why no heat
Whpool ele. dryer tumbles and blows, but timer no work and no heat. will bad timer cause no heat?
  • jim tatum May 18, 2009
    Thanks localwonder, but I need to know to test why timer no turn, it just stays at what ever point you set it.
    Beautiful localwonder, thank you very much.
  • 6,784 Answers
Absolutely. A bad timer will not initiate the element function once the load has started. there is a point on the timer board where, the timer sends a heat signal to the element and it also controls the shutdown signals as well. the high limit thermostat controls the actual temp once the timer initiates the heat signal. if the timer is bad or malfunctioning, the element will malfunctioning as well.
Replacing the timer will fix this issue.
Posted on May 18, 2009
  • Michael Masters
    Michael Masters May 18, 2009
    Ok, the timer mechanism is damaged. this mechanism is magnetic and if the mech becomes damaged, it will not be able to spin and time the load. if the timer is not spinning, its defiantly not working properly.
  • Michael Masters
    You can test the functions by connecting a ohm meter to the element terminal posts. select a cycle and, press the start button. if the meter registers any resistance/current and the element dose not heat up, this will show that the element is bad but, if the meter dosen't pick up a current or resistance signal, this will confirm timer failure.
    Scholar:
  • 42 Answers
Try the "good 'ol Xenophanes quick and dirty solution".
Go downstairs or to the garage and find the circuit breaker to the dryer.
Turn it off.
Count to 4 and one half and reset circuit breaker with a snap.
Go try out the dryer and see if it works.
Most times that is the solution.
If a dryer pops off one leg of the circuit breaker and not the other all sorts of odd things happen. But for sure the heat will disappear.
An occasional popped breaker is no problem, but if it continues on a frequent basis then you have a problem either in the circuit breaker or the dryer.
If it continues I'd replace the circuit breaker(s) before I did anything else.
good luck
Kenmore ele. Dryer 110.69522800 not blowing anymore, still tumbles and heats but no exhaust being put out, help!
First, open the unit and check to see if it is clogged with lint. If the unit is tumbling, then it should blow since the belt also runs the blower. If the blower is broke, here is the new blower to order.
Nov 22, 2012 | Kenmore Dryers
Dryer is tumbling,but timer and heat are not working
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101\]]
Jul 09, 2011 | Maytag MDE2600 Electric Dryer
Maytag performa dryer model-pdet920ayw will not heat. drum tumbles and timer works
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Dryers
Dryer runs...timer wont rotate and wont heat up
Good day,
Timer woun't run if there is n heat.
1. Check to see you are getting 230 volts to the machine. The motor uses only 115 so is not a good indication.
2. Remove back cover. You will need an ohm meter to test the components.
A. In the center bottom is a skinny white bakelite device held on with one screw. Remove one wire and check. It should check zero ohms. If not replace.
B. On the bottom right is a canister with the heating element terminals sticking out. They should test at 30 or less ohms. If not replace the heating element.
C. There are about 3 other limit thermostats in the area you're working. They should all check at zero ohms. Replace as needed.
Below is a tutorial on changing a heating element.
http://www.applianceaid.com/wp_element.html
Mar 02, 2010 | Whirlpool Dryers
Dryer not blowing hot air- timer not working
im assuming your on the automatic cycle. on this cycle the timer will not advance without heat. check you house circuit breaker/fuse. if one goes the unit will run but will not heat.
Feb 08, 2010 | Dryers
Thermal fuse blows Before this happened heat element went and dryeer would blow cold and not shut off until timer was manually turned off. Replaced all parts except timer. dryer worked for ten minutes and...
If you are referring to the thermal fuse on the tumble drier, my thoughts are that the airflow is being restricted.Cool air is meant to flow in the back air vent which cools the components. This causes air convection and allows the clothes to dry evenly. No airflow makes everything overheat and the first item to normally break is the overtemp. thermal fuse.Go from there.
Sep 23, 2009 | Dryers
KitchenAid Dryer Timer stopped working - won't stop drying
Timers cannot be repaired. The mechanism is a spring - once it weakens, or fails - a new timer is required.
CLICK HERE for your part.
It is $83.72 USD.
Here is a Buy-it-Now eBay auction for $34.99USD & Free shipping!!
CLICK HERE
Your part number for the timer is 3976570a
A used part would have to come from an appliance store that salvaged from an abandoned washer.... and it may fail shortly anyway.
The new timer will have a warranty, and give you 10 more years of service.
Well worth it.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 05, 2009 | KitchenAid KEYS850LQ Electric Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Whirlpool Dryer tumbles, but no heat, no timer.
try turning your breaker off then on and advise me
Dec 31, 2007 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
168 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
