Question about Hoover Dryers
Hoover vhc6918 dryer makes knocking noise
Sounds a bit like a train as if there is a high spot somewhere
  • 50 Answers
SOURCE: Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Posted on Sep 07, 2007
TheMobilian
  • 8220 Answers
SOURCE: dryer making noise sound like train going by
That's a bad blower wheel:2fb1a55.jpg
This is a real easy fix. Start here:
Posted on Dec 17, 2008
  • 1122 Answers
SOURCE: My kenmore dryer 90 serise won't start...makes humming sound....
your dryer motor is shot,it is to weak to kick on,sorry-mike
Posted on Jun 03, 2009
hunter19_46m
  • 7482 Answers
SOURCE: dryer making knocking sound
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Nov 13, 2009
  • 11 Answers
SOURCE: I have a Hoover 5030d
It sounds like the engine shaft bearing. Fairly simple to fix or replace with the correct tools and know how.
Be sure to take photo's of the motor, tension arm, and any wiring.
You'll need pliers to remove the clamp from the fan, then remove the belt from the motor and make sure that's were the problem is before going any further.
Posted on Dec 29, 2010
Want to use this on 220v aussie supply to power 1947 221 lionel train loco Suitable?
ohh no that id not try at all , one can first use a power converter that one can buy off many online sources to convert 220 volt down to 110 volt then to transformer this will be safe 4 unit, the 50HZ to 60 Hz doesn't matter to much as well unless one plans on using the lionel sound generator , then its not gonna sound to spry as it will be a bit slower !!
Jun 16, 2015 | Lionel O Train Transformer 6-14198
Proform_xp_800_vp My treadmill just starting
13c5a4bc-2f6e-452d-8456-f22742c60fa8.gifsee the video and lube, please do the same with rollers bearing front+back. Test the drive belt motor, and replace the belt if necessary
If after you lube the problem remain, is TIME to replace the DECK belt.
God bless you
Aug 02, 2013 | Exercise & Fitness
My 1996 4.3 liter gmc jimmy wont start and i have a weak spark, I changed the coil and driver along with the crank and cam sensor. I also changed the vcm and still it has a weak spark,
Hello
The engine and automatic transmission in this vehicles drive train are fully electronically controlled by a computer called the PCM and TCM (Power Train Control Module, Transmission Control Module). When a problem like this or other drive-ability related problems occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
Aug 28, 2012 | 1996 GMC Jimmy
My kennith cole watch skipping a beat on the 5th second. And everytime I set time It lacks behind
Watches with a low battery sometimes are programmed to skip and then double a pulse to get your attention. So, you might see the second hand of your watch pulse every 2 or even every 5 seconds, making bigger than expected moves on your dial. In each of these situations, though, your watch should still be keeping time overall.
The situation that you describe sounds more like you either have a defective gear somewhere in your movement, or, equally likely, you have a bit of dirt hat is gumming up one particular tooth on a gear somewhere in your movement.
On a mechanical watch, the usual solution is to service the movement, disassembling the gear train and washing the gears in a special cleaning solution. Each gear would then be inspected for imperfections and either honed or replaced so that the movement as a whole worked properly again. Unfortunately, very few battery-powered quartz watches are designed for this type of service. A watch repair service can try to run your watch at high speed using a special test rig to see whether that flings out any dirt. They can also inspect the watch movement, though the amounts of dust and dirt we're talking about can be too small to be easily spotted.
Bottom line advice: try replacing the battery to see whether that makes a difference. If it doesn't, there's a decent chance that you'll be in the market for a new watch.
Apr 27, 2012 | Watches
We have 98702. the dryer makes a loud rubbing, or knocking noise. at first listen, it sounds as if there were metal in the dryer rattling around. this is a steady noise. i am interested in fixing myself....
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 25, 2011 | Kenmore 98702 Stacked Washer/Dryer
Sounds like a train wreck. Started with a skreech. Now a train wreck
heatman101
Jul 23, 2011 | LG DLG5988 Stainless Steel Gas Dryer
My Atlantis dryer makes a clunking sound when running. It seems as though it happens when the same spot on the drum passes a certain spot on the left side of the dryer.
Hi, Belt is going bad... has a chunk out of it...
heatman101
Feb 10, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
My hoover dryer vhc392t makes a loud squeaking noise when in use can it be repaired
heatman101
Nov 23, 2010 | Hoover Dryers
Drier had a high shrieking noise. Noise stop now it's a knocking sound
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console will stay with it.
Remove the screws holding the lint filter housing in place, and remove the lint filter.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Sep 07, 2010 | Kenmore 700 6972 Dryer
My White-Westinhouse dryer is making alot of sounds
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps
Nov 19, 2009 | GE Dryers
Dryers Logo
29 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
