Question about Alpine CDE-143BT Advanced Bluetooth CD Receiver
Will not play the radio
Will show the volume but wont play the radio
Troubleshooting guide
look in owners manual it will show you how to reset radio playing code.if car lost power with radio on more likely lost radio code.
Nov 28, 2013 | Chevrolet Impala Cars & Trucks
Volume works but picture wont show
It is likely your TV has power supply trouble.
Nov 08, 2013 | Hitachi P42H401 42 in. Plasma HDTV
On my 2004 X Type Jag only the volume switch works on the radio unit its self cant change stations play cd of use the steering wheel controls as i said all i can do is turn the volume up or down? any ideas...
Did you find the problem with your radio Terry? I have a 2005 X type and the radio has just suddenly started doing exactly the same thing - cant change radio station or use steering controls, only the volume knob works.
Dec 05, 2012 | Cars & Trucks
Radio in 2003 jeep grand cherokee does not play cd's. it plays the radio stations, volume works, but it does not eject the cd or even recognize it .
you can look for a radio shop to repair the cd player it would be cheaper to install a aftermarket radio they do have kits if you have steering wheel controls
Apr 10, 2012 | 2003 Jeep Grand Cherokee
Radio continues to fade in and out, plays for awhile fades out
Need more information on this if possible.
It may be the speed volume is enabled on your radio, does it fade out when you start to come to a stop? Some vehicles have a speed volume setting in their radios in which the radio raises and lowers the volume during driving conditions, like when your comming to a stop, the volume will automatically lower and during faster driving speeds will rise to a higher volume.
Hope this helps
JD
Sep 10, 2009 | 2001 BMW 325
Radio is on but buttons wont work ,cd plays but wont come out
Radio is on but will not show stations and no sound from speakers. New radio receiver and relay.
Jul 26, 2008 | 1994 Chevrolet Corvette
Car stereo crash
IT SOUND LIKE ONE OF THE BUTTONS IS STUCK
Apr 28, 2008 | Car Audio & Video
Sony cdx -m8800
Remove the radio, disconnect the blue wire, and connect the blue/white wire in its place. This should fix your problem.
Sep 08, 2007 | Sony CDX-M8800 CD Player
XM 2 GO Not Playing
I had the same problem. I had to reset (use a paper clip into the RESET hole under the battery cover ( or pull out the battery for a a couple of minutes). Then, after recording some songs, I switched over MYXM and then began rotating the channel selector dial. The volume indicator arrow moved off zero and began advancing up the volume scale. I kept doing it until it about half way and my sound was back.
Nov 21, 2006 | Pioneer AirWave XM2Go Satellite Radio...
Alpine CDE-143BT Advanced Bluetooth CD Receiver Logo
20 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
