Question about Gaggia Carezza Espresso Machine
Sensors my moms 96 saturnSL1 all of a sudden started to run rough and smoke the service engine light came on so I got the code and it was p0340 wich says to check the cam position sensor but this car does not have one what could it be thank you
  • 186 Answers
Most likely it's a #1/#4 coil & spark plugs/wires.The P0340 is actually a fancy DTC for misfire.I would recommend new #1/4 Coil pack,New Plugs(A/C Delco NGK)& New plug wires.I would also strongly recommend checking the Coolant Temp Sensor & Connector.The have an updated sensor from saturn that's made of brass.It's located under upper radiator hose at cylinder head yellow/black wires.Check connector for corrosion,replace with sensor if corroded.hope this helps
Posted on May 21, 2009
Hi I have a 1997 cadillac eldorado 4.6l northstar engine. It went from normal to blows clouds of smoke out the rear exhaust. Run sluggish.
clouds of smoke out the rear exhaus ,What color ? blue smoke is oil , white smoke is most of the time coolant is getting into the engines cylinders , Black the engine is running rich ,too much fuel . DTC P0135 HO2S Heater Performance Bank 1 Sensor 1
DTC P0147 HO2S Heater Performance Bank 1 Sensor 3
DTC P0340 IC Module Cam Reference CKT No Frequency
DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient
P0441 has nothing to do with the gas cap !
DTC P0441 Evaporative Emission (EVAP) System No Flow During Purge
DTC P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
P0441 & P1441 will be back , may take a day or two , but will be back because gas cap has nothing to do with it .
Honestly , you should take your vehicle to a qualified repair shop !
Feb 06, 2017 | Cadillac Cars & Trucks
What are the probable causes of DTC P0340 other than a defective CPS?
Symptoms can include: Hard starting or no start
Rough running / misfiring Loss of engine power Causes
A code P0340 could mean one or more of the following has happened:
a wire or connector in the circuit could be grounded/shorted/broken the camshaft position sensor may have failed the PCM may have failed
there exists an open circuit
the crankshaft position sensor may have failed
Possible Solutions With a P0340 OBD-II trouble code,
diagnosis can be tricky at times. Here are some things to try: Visually inspect all the wiring and connectors in the circuit Check for continuity in the circuit wiring Check the operation (voltage) of the camshaft position sensor Replace the camshaft position sensor as required Check the crankshaft position circuit as well Replace circuit wiring and/or connectors as required Diagnose/replace the PCM as required
Read more at: http://www.obd-codes.com/p0340
Copyright OBD-Codes.com
May 06, 2016 | Nissan Maxima Cars & Trucks
Engine runs rough
fix the first two
clear the codes see what is left
P0340 Camshaft Position Sensor Circuit Malfunction
P0171 02 sensor
System Too Lean (Bank 1)
if no better . these are unusual codes
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0304 Cylinder 4 Misfire Detected
P0219 Engine Over Speed Condition
fault code source
Complete List of OBD Codes Generic OBD2 OBDII Manufacturer Car OBD...
Mar 23, 2017 | Cars & Trucks
Engine running rough all of the sudden
Try Maf sensor,(Mass air flow)
Then try tps sensor, (throttle position sensor)
Unable to answer exactly without looking up codes
Feb 16, 2014 | Cars & Trucks
Tcs light flashes and p0340 code
P0340 code means "Something" is wrong in the timing...
from CMP (Camshaft Position sensor) to the crankshaft bolt.
Very first thing, verify connectors are clean and shiny.
clear all codes, even hard codes.
Nov 23, 2013 | 2005 Mazda 6
Got code po340 on 2008 Chrysler PT cruiser. Runs great sometimes when engine light on & rough at other times like not getting gas. Engine light does not come on every day either. Cam sensor or timing...
P0340: Camshaft Position Sensor A - Bank 1 Circuit Malfunction
- Camshaft Position Sensor harness is open or shorted
- Camshaft Position Sensor circuit poor electrical connection
- Faulty Camshaft Position Sensor
- Faulty starter motor
- Starting system circuit
- Dead (Weak) battery
Feb 08, 2012 | 2008 Chrysler Pt Cruiser
2003 sebring 2.4l ck engin light on code po340 can you help
P0340 - Camshaft Position Sensor Circuit Malfunction
This indicates that a problem was detected in the camshaft position sensor circuit. Since it says circuit, that means the problem could lie in any part of the circuit - the sensor itself, the wiring, or the PCM. Don't just replace the CPS (camshaft position sensor) and think that will definitely fix it.
* Hard starting or no start
* Rough running / misfiring
* Loss of engine power
Causes: A code P0340 could mean one or more of the following has happened:
* a wire or connector in the circuit could be grounded/shorted/broken
* the camshaft position sensor may have failed
* the PCM may have failed
* there exists an open circuit
* the crankshaft position sensor may have failed
Possible Solutions: With a P0340 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
* Visually inspect all the wiring and connectors in the circuit
* Check for continuity in the circuit wiring
* Check the operation (voltage) of the camshaft position sensor
* Replace the camshaft position sensor as required
* Check the crankshaft position circuit as well
* Replace circuit wiring and/or connectors as required
* Diagnose/replace the PCM as required
Test it and keep us updated.
Mar 11, 2011 | 2004 Chrysler Sebring
3.9 v6 4x4 check engine light, runs rough
Replace the ECT sensor.
And letme know. If you feel any diference. ok.
Aug 15, 2008 | 1998 Dodge Dakota
Gaggia Carezza Espresso Machine Logo
204 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
