Question about RCA Televison & Video
I have RCA LED55C55R120Q. Powered off TV and Cox DVR box and blue screen appeared on TV. I see there is a way to disable the blue screen but would like to know why I would want this blue screen func
RCA LED55C55R120Q
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
Posted on Dec 03, 2008
SOURCE: connecting COX DVR and Phillips DVD to Vizio HD TV
we connected the cable box to the coax connector while our philips dvd went into the HDMI1 connector, and we got both working fine and dandy
Posted on Jan 12, 2009
  • 3 Answers
SOURCE: The screen shows ''Weak Signal'' and no picture.
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Posted on Mar 21, 2009
macgroovy2
  • 52 Answers
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Posted on Jun 18, 2009
SOURCE: Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
Posted on Sep 07, 2009
RCA LED LCD TV Vertical Line Problem
Sounds like your display driver board is broken. Try claiming warranty.
Jul 02, 2016 | RCA LED55C55R120Q 55" LED TV 1920x1080,...
Top and bottom of the screen are cut off
That set has an aspect ratio of 4:3. The problem is that what you are sending to it is 16:9 So you are sending an hd signal to a non HD television. The tuner is NTSC which is not HD. Theres not much that you can do about this.
Jan 17, 2014 | RCA F27650 27" TV
RCA LED55C55R120Q when I power DVR and TV off with cable remote, blue background remains on TV.
The code the cable remote is using is only partially controlling your TV.Try a different code for your cable remote for your brand of TV ... OR check the cable manual to have the (cable) remote controller search and "learn" the TV settings.
Dec 28, 2013 | RCA 55" Class 54-5/8" Diag. - LED - 1080p...
Model l32hd31r will not work with cox cable box.
The Cox cable box,work before?Talk to Cox cable customer seviced send u another box?Tries unplug the tv and the cable box,replug the tv and the cable box back an hour later.Tv should reset itself back to factory setting.The cable box should update it software.They might work,if they reset themselves.
Oct 06, 2010 | RCA L32HD31 32 in. LCD HDTV
Jun 02, 2009 | Vizio VX37L Television
Is tv an HD tv
Yes, mostly all new displays are at least 720p which display a great picture ! However, coax cable is the worst possible cable you can use. Your best bet for HD from the cable box is to use component cable. These are the 3 RCA type colored cables, red, green and blue. You will also need another two RCA cables for the audio, which is usually red/black or red/white. If you have a surround sound receiver, then you will not need the 2 for audio to the TV. These 2 would goto the receiver or you can use a better digital coax or optical cable for audio.
Also, HDMI from the cable box to display is a more expensive cable which will give you HD but doesn't always look better then component on some HD cable boxes.
Mar 11, 2009 | Philips Televison & Video
Picture goes blank but audio on
If you are using component cables to connect your HD box to TV. Make sure your connections are tight. You should make the colors match up. Green, Red, Blue. Check on both TV and HD box. Make sure HD pox is powered on. Make sure to select TV input to Component 1 or whichever you are using. If this doesn't work you may need to call and have COX refresh the HD box. This can be done over the phone. This will make sure you are receiving and sending the proper signal level. Good luck
Oct 05, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Televison & Video Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
