Question about Pioneer VSX-305 Receiver
I have a reciever VSX 305 that had a 6.3A/125v fuse blow I don't know where to get a replacement
4 Suggested Answers
  • 7 Answers
SOURCE: I have a Pioneer VSX-454 reciever, both 1.25 Amp fuses blown
blue two legged varacter on power supply board needs to be replaced
Posted on Jul 12, 2009
  • 4 Answers
SOURCE: no power
Press TUNE+ & AUTO SURR/DIRECT keys continuously for 2 sec. and it will tell you the fault it encountered if the receiver is in otherwise working condition.
Posted on Aug 12, 2009
Grubhead
  • 5158 Answers
SOURCE: I had a bad speaker wire on my Pioneer vsx-305 and
You can get fuses from any electronic parts shop, such as Maplin (UK) or Radio Shack (USA). I would get a few, because chances are the fuse did not just blow because of a bad speaker wire! Fuses are there to protect the device from an overload (which would cause a fire). The mostly likely cause of your fuse blowing is that your wire shorted out an output transistor on the channel the speaker was connected to and the transistor is acting like a piece of wire now!
If you have an Ohm meter I would put it's probes on the terminals of the transistors on the heat sink. You will soon know, as it will be just like you have touched the meter's probes together!
Posted on Apr 26, 2010
I had a bad speaker wire on my Pioneer vsx-305 and the 125v 6.3a fuse blew. Where could I find a replacement fuse?
Apr 25, 2010 | Pioneer VSX-305 Receiver
HTR-5280 Receiver Fuse Blown
the fuse rating should be printed at the back near the fuse holder itself. If it opens the fuse again and again probably you have a circuit loading problem in the receiver...either one of the amps is failing.
Aug 10, 2009 | Yamaha HTR-5280 Receiver
Jul 12, 2009 | Pioneer VSX-454 Receiver
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
No power
Mar 12, 2009 | Pioneer VSX-818V-K Receiver
Indentifying fuse type on tac0151 chassis
Are just regular fuses 5A/125V. You can replace them with anytype 5A fuses.
Jan 05, 2008 | Toshiba 50H81 50" Rear Projection...
6.3a slow-blow 125v fuse
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
Blown Fuse, needs fix'n
You CAN open the unit (keep in mind that even unpluged there is still voltage runing through the system, so.... dont fry) and you will notice, if the face of the unit is towards you you will see on the left hand side a power supply board, the fuse is on that board, and it is a tube fuse, 125V 8A. Most stores do not carry the 125V version anymore, but will carry a 250V. This is okay to use where the voltage is not the main purpose of the fuse.
Oct 19, 2007 | Onkyo HTR500 Receiver
Toshiba 50H81 TAC0151 Blowing Fuses, I Need schematic
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
Sep 09, 2007 | Toshiba 50H81 50" Rear Projection...
203 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
