Question about Sharp LC60LE820UN LCD TV
Firmware updateslc-60le820un - Sharp LC60LE820UN LCD TV
1 short 1 long blink on sharp aquos LC-60LE820UN
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 24, 2016 | Sharp AQUOS LC-60LE820UN 60 inch LED HDTV
Tip
3COM 3CRWDR200A-75 Firmware Download - All Versions
Hello
If you want earlier firmware versions of 3Com 3CRWDR200A-75 then check this website:-
http://3crwdr.googlepages.com/
da4eeaf.jpg Firmware Router 3Com 3CRWDR200A-75 V.3.0.1
Firmware Router 3Com 3CRWDR200A-75 V.3.1 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9b Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b7 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b6 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b4 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b Beta
_____
Regards
on Jun 29, 2008 | 3Com OfficeConnect Wireless Router
How do i test a backlight for a led tv
Testing TV Backlight LEDs - YouTube
? 4:44
https://www.youtube.com/watch?v=eEJoPCa7Kt0
Jan 24, 2015 - Uploaded by swappart.com
... explaining easy way to test individual LEDs on a strip from aTV backlight. ... Sharp LC-60LE820UN TV - LED Strip Testing - Long Version ...
IT02 - How to Test LED Backlight - YouTube
? 0:55
https://www.youtube.com/watch?v=YmSI2N6BGPA
May 20, 2011 - Uploaded by LCDPARTS
How to use IT02 to test Laptop screen LED backlight.
LST04-TV, How to test LED TV screen - YouTube
Dec 26, 2015 | LG Televison & Video
Hi I have a Sharp aquos tv that won't turn but does weird things. is there an easy diy way to fix this.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 17, 2015 | Sharp AQUOS LC-60LE820UN 60 inch LED HDTV
My Sharp aquos won't resond to remote
Replaced Battery of remote.keep your mobile camera ON and press any from remote.If you get flash light in camera that means your remote is ok. Checked & Replaced LED TV sensor pcb.
Jul 26, 2014 | Sharp LC-60LE820UN AQUOS 60 In. 1080p LED...
The light in the middle bottom of screen is blinking with no picture
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 29, 2014 | Sharp AQUOS LC-60LE820UN 60 inch LED HDTV
Slow wireless connection
Make sure you have a n series wireless router. Also wireless routers especially g, n series, or 2.4-4.8 are line of site frequencies. That means you will get better reception if your wireless device is in the same room as your router.
Jan 27, 2014 | Sharp AQUOS LC-60LE820UN 60 inch LED HDTV
Sharp LC60LE820UN LCD TV Logo
29 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
