Question about Motorola Mobility Nextel i500/ i550/ i700 Rotating Cell Phone Holster 2-Way Radio
Hi, I have 6 units i700 motorola that where use with NEXTEL, someone told me that they can be fix to work as walkie talkies, can you help me with information. Thank you for the time. Eduardo Saucedo Mester eduardo@saucedo.com
  • 19,396 Answers
Motorola i700 plus has already built in walkie talkie function.
The function is called private calls.
Using Private calls you can talk between two phones on a one-to-one conversation.
See the chapter at page 34, Making Private Calls on the manual below:
Motorola i 700 plus User's Guide
Regards.
Posted on May 19, 2009
Motorola walkie talkie randomly cuts off
buy professional radios and you get better battery contacts
dont go to work with child's toy
Mar 22, 2012 | Motorola Walkie Talkie 2-Way Radio
Where can I find an authorized repair center for Motorola Walkie Talkies near Pensacola, FL 32505?
I work for the authorized motorola dealer for pensacola, but i work in another branch. Typically we do not service the "walkie talkie" line that motorola makes. For those, you should contact motorola directly. Here is their contact link:
http://www.motorola.com/Consumers/US-EN/Contact-Us/Corporate
Jan 11, 2011 | Motorola Walkie Talkie 2-Way Radio
Motorola walkie talkie need to be tuned up. We have 12 some work some don't. We are in Weehawken n.j. Is there someone close that can fix?
have you checked the batteries first, not exactly knowing what you mean by not working,the batteries are a good and easy start to a fix,then if they are working i.e. you can see the read-out, then re-set all radios to de-fault factory mode and see if this makes them all operational I'm at 24/7 Appliance Service and T.V. repair located in southern Wis. Ph# (608)214-5632 Thank You Daniel
Oct 28, 2009 | Motorola Walkie Talkie 2-Way Radio
Cant make calls
go to settings / advanced/ connectivity / master reset. You have to perform master reset for the phone to work.
Nov 15, 2008 | Motorola Mobility i880 Cellular Phone
Cellphones with walkie-talkie features
Nextel uses WIDEN (network) for most two-way communication. Some, if not all, have DirecTalk. This is a feature which allows communication as a short range radio allowing everyone on your channel in the same mode to hear you.
Nov 06, 2008 | Motorola Walkie Talkie 2-Way Radio
Unlock codes
You may need to purchase a new sim card for it to be compatible with your nextel phones BUT it won't hurt to call customer service and try to activate that sim card under the ic902's serial number. Because your ic902 is also a sprint phone it works off of a different network and will need programming. Customer service will be able to activate your phone and give you the info needed to get your phone up and running.
Oct 20, 2008 | Motorola Mobility i870 Cellular Phone
Nextel i850 can't receive calls
  • may be the walkie talkie can recieve signals only to an certain distance,so it may be due to the signal problem........
  • if the reciever is beyond the permitted distance it loose its frequency...........
  • or else the person who is calling walkie talkie might not hav signal in that area.....
  • and if the walkie talkie does not recieve any signal then the receiver component present inside the walkie talkie might be damaged.........
  • and if it does not reply to an signal transmitter might be damaged..........
  • i hope my answer would be sufficient for u.....thank u......
Sep 10, 2008 | Motorola Mobility i850 Cellular Phone
Walkie-Talkie wont work and the Outside buttons wont work.
This is called the PTT buttons Back housing assembly: Open your phone make sure the wire is attached correctly: If the wire is attached correctly you need a new back housing. www.cdphonehome.com Nextel Repair Parts
Oct 30, 2006 | Nextel i860
Radio Communications Logo
56 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
